He351, 366, and pump maxed today!
Old Jun 13, 2009 | 11:30 PM
1stgenjake's Avatar
wow now i really need to do the clutch. I also need a boost controler of some kind because i can now boost over 50 psi with out taching it out...thats too much. but just before the clutch really ate it i did a roll on burn out at about 50 mph in 5th gear, it had rained about a hour but ive never had 5th gear traction issues before
Old Jun 14, 2009 | 12:51 AM
12vkaleb's Avatar
Did you have to buy another (he351). Where at in ohio are you? Im right outside of columbus.
Old Jun 14, 2009 | 12:05 PM
Nice!
I thought you had got an HE341 ?
Old Jun 14, 2009 | 07:29 PM
Riflemanusmc's Avatar
Registered user
Nice!
He does.. BAD Ebay seller that snaked the man... He bought a 351.
Old Jun 14, 2009 | 10:31 PM
1stgenjake's Avatar
im up by youngstown ohio
Old Jun 14, 2009 | 10:34 PM
Alwaysworking's Avatar
alwaysonDTR
any idea what clutch your going to get?
Old Jun 14, 2009 | 10:54 PM
1stgenjake's Avatar
i have a valair sitting here waiting to go in
Old Jun 14, 2009 | 11:00 PM
alwaysonDTR
whats it rated for?
Old Jun 15, 2009 | 09:43 AM
1stgenjake's Avatar
300hp 700ftp. i know it won't last long but im its a daily driver and its always empty. since i already have the clutch my teacher and i are putting it in tomorrow
Old Jun 15, 2009 | 01:13 PM
jesussaves's Avatar
for a cheap boost controller just hose clamp the wastgate line. tighten to your desired boost level
Old Jun 15, 2009 | 11:13 PM
1stgenjake's Avatar
i got a 50psi boost controller today for $100. i'll be able to adjust boost from in the cab so now im on a hunt for a lift pump that will sent fuel long enough to stay on it and she'll be ready to dyno/race
Old Jun 16, 2009 | 12:08 PM
Just get a low PSI piston pump and line from your nearby cummins dealer. Part #'s are in the sticky.
YOu'll need the, pump, the spacer, cut away some insulation on the block, and maybe the line to go from the lift pump to the filter block, or you could make the line.
Its a great upgrade.
Old Jun 16, 2009 | 12:51 PM
1stgenjake's Avatar
ok thanks
Old Jun 16, 2009 | 04:45 PM
PM'ed you back
Brendan
Mar 15, 2010 02:59 PM
pwrtripls1
Oct 23, 2008 05:32 PM
tomgreentwin
May 24, 2006 08:50 AM
pwrtripls1
May 28, 2005 04:00 PM
