Max RPM 90 W/Turbo
Max RPM 90 W/Turbo
I Put the 90 5.9 in my 74 Dodge 4X4 I have 3:55s if I run 65mph at 2500rpm will this hurt the motor and could I run higher rpm for a long time? I'm depending taking it on a trip 400 miles next week or take the 01.
Thanks for the information on RPM, I'm running the standard Auto 3 speed. I'm looking for a 5 speed 94 up what would be a good price for one? and then I need to find the linkage for the 74 I hope in the next couple weeks I'll have pictures on my web page So far every one likes it and the local Diesel shop is very impressed how it fits and with 4" stacks and paint job.
http://www.gearvendors.com/ddrive.html
note: most auto 3 speeds had 3:07 in them......3:55 is going to be a slow, low fuel milage run...it will make it in flying colors though!
Auto wrecker's and or new part prices: Bellhousing $100-$125 [should come wih release arm and 4338855 release arm retainer clip], flywheel $100-$225, clutch kit $350-$1,300 [kits come with pilot bearing, alignment tool, pressure plate and release bearing] master cylinder $75-$100, slave $75, pedals/linkage $25-$100, NV4500 $600-$1,250 [often w/o shift lever], NV4500 trans mount rubber isolator $35, plus you'll need Syn Torque trans fluid at about $60 and be sure trans has 5th gear nut fix or the shaft Flash is talking about. So over $1,400 low ball on part by part or $2,300+ getting reamed on prices: cheaper to buy a wreck and strip it.....
Dually Driver
13
11-13-2007 09:10 PM
belfert
09-09-2004 03:23 PM
fishin fever
02-22-2004 08:32 PM
Zino
08-15-2003 10:14 PM
