Edge Milage Max or Quadzilla Max Milage
Was up in FW 2 weeks ago and went by Quad. Swapped my old XZT for the new module with Max Mileage loaded on #1. Got 11.53 mpg pulling my 10K 5er back home...but, this was constantly changing speeds between 35-50 mph due to pea soup fog for the last 100 miles.
Unloaded, (just comparing fuel gauge readings) made usual drive to work and it "seems" like I may have picked up 50 miles per 1/2 tank. Will be able to post some HC #s in about 8 days.
I picked up 1.5 mpg with the MM tune loaded on my X2 XZT. That is running empty on my daily commute. That was hand calculated over 2 tanks of fuel. I am going to run the MM tune on our next trip with the trailer just to see if I see any gain while towing.
The Quad module mounts under the dash. Go to www.quadzillapower.com and you can download the .pdf for install instructions. Highly recommend the Commander too; allows switching levels and great monitoring. IMO.
Hey Keith!
Hey Keith!
the quadzilla mileage module ads no fuel pressure or boost fooling and only adjusts injection timing. at 20psi boost or above the box reverts to stock so if you are running hard or towing very heavy up hill you wont see any improvement. if you keep the boost under 20psi it should help a bit. seems like they advertise 12%? I dont have the MM yet but have the commander sitting here ready to be installed.
Are these mileage boxes essentially an edge EZ or edge juice with only the level 1 setting available? Does anyone know how much rail pressure the edge mileagemax box uses compared to an edge EZ or edge juice on a 2004 305/555?
been on the phone with the techs at quadzilla and asked them specifically about this box and was told by chris in the tech department that the MM DOES NOT ADD FUEL OR BOOST FOOLING. only changes timing. you can ask them yourself by calling and ask for the tech department at 888-842-6572. now, this box is upgradeable and you can download more powerful programs that will add both fuel and boost if you like but it doesnt do that stock. its just for fuel mileage not power.
"qoute from quadzilla web site"
The max mileage module will not put your engine or powertrain at any risk. This product actually lowers egt's. It does not raise boost over stock levels and does not add any fuel to your engine. Because of the way this increased efficiency works , you will gain noticeable performace while empty or towing. These perforamance gains will not affect the transmission under any circumstances!!
cemt8
Sep 29, 2008 09:27 PM
sinawalli
0
Jun 18, 2008 10:09 PM
fflarry
18
Feb 22, 2008 05:57 PM
Billwie
Dec 15, 2007 01:04 PM
