Can I stack a Quadzilla Max Mileage Module with Edge Juice with Attitude?
Old Sep 28, 2008 | 09:13 PM
cemt8's Avatar
Has anyone tried stacking a Quadzilla Max Mileage Module (M3) with an Edge Juice with Attitude?
I get 26 mpg with the Quad M3 alone, but only 20-21 with Edge alone on the mileage setting.
I would like to put both on and get the benefits of the M3 when the Edge is set to stock, but get the power benefits for towing when the Edge is set to towing.
Any thoughts on if this would work or if it would cause any problems. Right now I am doing the swap manually... When I tow I hook up the controls part of the Edge and when I am just driving I unhook the Edge (except for the data plug for gauges) and hook up the M3. It is kind of a hassle...
Thanks!
Old Sep 29, 2008 | 09:27 PM
bighornram's Avatar
The Mileage Max is not designed to be stacked. Meaning run with another module on at the same time. As far as physically hooking both up at the same time I would think it should work. But I would leave the Edge set on '0'. I believe they get the better mileage through mainly timing advance so both on at the same time may be a bit much. Maybe someone has some actual experience to share with you on this. Or you could just try it and let the rest of us know how it turns out...
MMarty
Sep 25, 2008 06:44 PM
chadsdodge
Jun 10, 2008 12:37 PM
Joe N.
Jun 8, 2008 02:25 PM
planetdell
Oct 12, 2007 02:44 PM
coparam4x4
Sep 5, 2007 01:01 PM
