Master Cylinder Bore Size?
Old Nov 9, 2015 | 10:17 PM
1972RedNeck's Avatar
Could anybody tell me what the bore is on the stack first gen clutch master cylinder? I am doing a swap on a '66 Ford and am trying to figure out if I can use a Ford master cylinder...
Old Nov 9, 2015 | 11:19 PM
Usually they are 1.125" or 1 1/8".
Old Nov 10, 2015 | 09:01 AM
Were there different sizes between '89 and '93?
Old Nov 10, 2015 | 04:25 PM
j.fonder's Avatar
according to raybestos, its the same MC from 89-93 and yes, they are 1 1/8"
Old Nov 10, 2015 | 05:47 PM
jerseybud's Avatar
Guys, he's apparently talking about the clutch master cylinder? Which is 7/8 out of a diesel w250.
So which do you want to know, OP?
Putting a Cummins in a 66 Ford? Sounds cool so far.....
Old Nov 10, 2015 | 10:39 PM
Your right....Dohhh!
Old Nov 10, 2015 | 11:59 PM
You're right. The Ford clutch master cylinder is 1 1/8". If the Dodge ones were only 7/8" that may present some problems as I was hoping to use the stock Dodge slave...
Thoughts? Mixing the two would result in a stiffer pedal and blown apart slave cylinder, right?
Old Nov 11, 2015 | 06:18 AM
j_martin's Avatar
True dat if the stroke on the master cylinder is the same. Pedal geometry needs to be considered in the calculation.
If you're using the stock Dodge pedal linkage, you'd need the smaller MC.
Old Nov 11, 2015 | 07:25 PM
I didn't think about the stroke. I am trying to use all the Ford parts (pedal, linkage, cylinder). Anybody know the stroke of the master cylinder?
Old Nov 12, 2015 | 07:25 AM
j_martin's Avatar
What you need to figure this out is the dimension on the pedal arm between the pivot and the push rod for both linkages to compare.
Then you can do some math and figure out how much fluid each will push with the same arc of pedal motion.
If the pedal positions (either pedal or pivot) are different, you'd have to include the dimension between the pedal and the pivot in the calcs.
Old Nov 12, 2015 | 07:52 AM
Pedal travel could also be different too. I'll try to get some measurements off of a buddies truck.
subvetmmcs
MDDTR #33
Jan 13, 2010 06:38 AM
408dakota
Dec 14, 2009 12:58 PM
Gen414
May 7, 2009 11:08 AM
Checkmate
Apr 14, 2008 12:15 PM
cgmorgan06
Nov 15, 2007 04:02 PM
