Master cylinder?
Old Apr 22, 2007 | 09:22 AM
Mr. Jimmy's Avatar
Master cylinder?
Is the front reservoir in the master cylinder used for the front or rear brakes on a 93 CTD?
Old Apr 22, 2007 | 09:40 AM
BC847's Avatar
1st Generation Admin
The larger reservoir serves the front disc brakes. The smaller reservoir serves the rear drum brakes.
Old Apr 22, 2007 | 02:53 PM
Mr. Jimmy's Avatar
The 93 is loosing fluid from the small reservoir and I have replaced both rear wheel cylinders. I can't figure out where the fluid is going. Any ideas? Also the brake dashlight is on, but brakes are working great.
Old Apr 22, 2007 | 04:11 PM
Into the vacuum booster.
Old Apr 22, 2007 | 05:37 PM
Mr. Jimmy's Avatar
Is this a common problem?
How do I check for this?
Is a new Vaccum booster required?
The pedal effort seems to be normal.
Old Apr 22, 2007 | 07:43 PM
Yes.
Pull the master off, the booster will be wet behind it.
Yes.
The brake fluid hasn't eaten the diaphragm - yet.
Old Apr 23, 2007 | 08:51 AM
Mr. Jimmy's Avatar
Thanks, I will check the booster out.
Old Apr 29, 2007 | 06:09 PM
BC847's Avatar
Unhappy
Stinky!
So with my recent brake system overhaul, and installing the rebuilt master cylinder, I've most likely tweaked the OEM diaphragm so it's sucking brake fluid from the new MC?
Old Apr 29, 2007 | 06:27 PM
I don't see how you would have done that? The booster won't take out the master, it happens the other way 'round.
Old Apr 29, 2007 | 07:20 PM
BC847's Avatar
Question
I can't believe I'm typing this but I believe I'm loosing brake fluid from the MC/Lid interface when I launch really hard.
Just before installing the rebuilt unit, I painted it all nice and purdy. I've a number of streaks now coming from under the MC lid.
It's either a poor seal which I can't seem to identify,
Or,
The new rear disc brakes are slugging fluid, . . . . .. or something.
Old Apr 29, 2007 | 07:31 PM
I'd try another lid.
Old Apr 30, 2007 | 09:26 AM
Jims92CTD's Avatar
Lid Seal
I have replaced mine a couple of times. The only place I could find one was the dealership. The price was not to bad, NAPA had no clue.
Jim
Old Apr 30, 2007 | 04:20 PM
QIK2D's Avatar
just a note, the diaphram in most boosters is resistant to brake fluid (kinda like the boots on the wheel cylinders). it's almost like they figure brake fluid may end up in there.
Old Jun 15, 2007 | 01:37 AM
LittleHoe's Avatar
ok I am having the same problem, the dealership told me it was the master cylinder so I replaced it myself with a reman one from napa, and guess what, it is still leaking only now on the new one I can see it is coming from under the lid. The clip is super tight already and I don't think i can get it much tighter. So I don't have any more Ideas. it is a new master and cap and gasket and still leaking. Any help you all could offer would be appreciated.
Is there a different upgraded gasket that can be bought for it?
Gen414
May 7, 2009 11:08 AM
cgmorgan06
Nov 15, 2007 04:02 PM
Heeler00
Feb 18, 2004 01:52 PM
May 13, 2003 09:44 PM
