lost on how to make the dang cruise control work..
so some might have seen.. but i swapped the 518 for a getrag.
all is good now, except for the cruise.
i got the clutch interlock switch hooked up, and the neutral safety switch wire grounded to the frame.
truck starts with the clutch pedal depressed like it should. no cruise.
tried disconnecting the neutral safety wire on the frame and truck will not start.
so that said im kinda lost.
i would love this to work like it would from the factory if possible..
The cruise system shouldn't have anything to do with the transmission safety system. But then the PCm these later trucks run I might be wrong.
If it was the pre-89 system then I'd be more help.
thanks. looked it over.
got an idear, will try it in the morning.
it just bugs me because it worked great prior to be killing the auto and sitting for a month during the swap.
The netural safety wire can not be grounded all the time. It needs to be grounded to start. Then it needs to be an open circuit. The starter relay has a wire from the netural circuit to the PCM.
You need to install the pedal safety switch or use a toggle switch or rig a relay to controll the netural circuit. Removing pin #30 from the PCM plug is the other way.
'strokeThis_'07
18
Dec 17, 2007 11:34 PM
boomerang
Dec 11, 2007 07:56 PM
hotdram
Oct 27, 2005 10:42 PM
