lift pump install ?'s
Old Jan 12, 2008 | 01:52 PM
dodgethis91cmns's Avatar
so my lift pump is leaving a residual stain on my black and im guessing its bad. wannadiesel told me that i should look into replacing it soon. so i found one at napa for about 75 bucks. but how do i install it? do u attackit from the top or the bottom? is there going to be alot of fuel that leaks out? and when u put it on is there any specific way to put it in or should you just slap it on there? will it let air in the injector lines? hopefully theres some out there that knows what they are doing cause i dont
sincerely
nick
Old Jan 12, 2008 | 02:04 PM
Through the fenderwell and/or from the top. Take off the tire for better access.
You will lose a little fuel, not a lot.
Scrape ALL the old gasket off.
Put some grease on the lever that rides on the cam lobe for break-in lube.
Before trying to start it, open the bleed screw above the filter and pump the primer lever until you get clear fuel. Close the bleed screw, start truck and enjoy.
Old Jan 12, 2008 | 02:28 PM
dave i swear you are like some kinda of encyclopedia of first gens. thank you very much. not it all seems easy and clear.
Txwelder
Nov 26, 2025 01:53 AM
BC847
Apr 29, 2019 10:35 PM
caper
Apr 16, 2006 01:45 PM
Txwelder
May 19, 2005 06:10 PM
GSP
Oct 13, 2004 12:35 AM
