HELP: electrical issues?!?!?!?!
Old Jan 11, 2008 | 08:21 PM
ryan10's Avatar
Hey guys, tonight my dash lights went out. my turn signals and hi-beam lights and low fuel light still work, but the gauges do not light up? also, at the same time my running lights in the rear of my truck went out, along with my plate lights, but the brake lights and turn signals still work back there. Then, my radio started to skip pretty good. what is wrong? i need this fixed asap.
thanks.
Old Jan 11, 2008 | 08:25 PM
SkinnyBTN's Avatar
Replace all fusible links with a fuse box. My 91.5 started having electrical issues that made no sense. The guys here told me to do the same and untill I did, the probs continued. JMHO. Good luck!
Old Jan 11, 2008 | 08:28 PM
ryan10's Avatar
Also, the horn stopped working?
This all happened at the same time?
what could be causing this? What is the big white thing on the fuse box? i wiggled this, and my rear running lights flickered back on for about a second?
thanks.
Old Jan 11, 2008 | 09:05 PM
charger 69's Avatar
burnt wire
Mine did the same thing, it burned a wire between the back of the light switch and the back of the fuse block
Old Jan 11, 2008 | 10:26 PM
Boatnik's Avatar
Take a look at the harness connector to the head light switch. Mine was melted along with the switch. Both are available at NAPA and other auto parts houses.
Old Jan 11, 2008 | 10:37 PM
ppiggppenn's Avatar
Thx for that Boatnik, ...any chance you have a p/n for the harness? I got a switch but when I got in there I found the harness block terminal worse than the switch. I've since installed a bunch of silly circuits with switches and fuses but this makes it so only I know how to work things, ...er, on second thought I'll leave it as is ...
Old Jan 12, 2008 | 06:34 AM
ryan10's Avatar
Ok, how do i remove the light switch to inspect the wires?
thanks.
Old Jan 12, 2008 | 07:18 AM
Chrisreyn's Avatar
Ryan, you need to pull the gauge cover from the dash, and then then remove the headlight pull ****.
To pull the ****, reach under teh dash to the rear of teh headlight switch, feel around and you'lleventually find a spring loaded pin. When it is pushed in, it releases teh **** and shaft the **** sits on, they will pull straight out from teh dash.
Once the **** is removed, loosen teh nut holding the switch inplace and you can then pull the switch out from under the dash.
First time you do this, its kinda a pain, butonce you see how it goes together, its really pretty simple.
have someextra fuses on hand, youll likely pop one as you pull the switch out.
Old Jan 12, 2008 | 03:11 PM
ryan10's Avatar
OK, well it was not the switch? all running lights are out, and the horn does not work? is there a fuse block on the fender that controls these?
thanks.
Old Jan 12, 2008 | 03:43 PM
ryan10's Avatar
OK, so my hazards flash, my turn signals work, my headlights work, and my brake lights work, but NO running lights work, my gauges do not illuminate, and my horn does not work? I replaced the switch and it was not that. what should i check next?
thanks.
Old Jan 12, 2008 | 03:53 PM
leper's Avatar
Look for a different fuse or fusible link that is bad.
Old Jan 12, 2008 | 03:58 PM
leper's Avatar
fuse #4 (20 amp) is probably your problem
Old Jan 12, 2008 | 04:00 PM
Check your cigarette lighter for a dime...
Old Jan 12, 2008 | 04:01 PM
leper's Avatar
call me if you can.
Old Jan 12, 2008 | 04:07 PM
leper's Avatar
Fuse #4 (cavity 14) controlls: tail lamps, parking lamps, side marker lamps, licence lamps, front and rear clearance lamps, radio intensity, and horns.
Do your "ait to start" and WIF lights ome on at all?
nojodas67
May 26, 2012 06:27 AM
Thiss
Sep 28, 2010 10:41 AM
kevellis32
Mar 14, 2010 12:29 PM
StevenAg03
Jan 12, 2009 07:40 AM
