Lift Pump
I canceled my order for this pump from OFI after I found out it was a Delphi brand pump. That Delphi part # does not cross reference to the low pressure Cummins LP #. Delphi # HFP702 is cross referenced to Cummins # 3918076. I guess I'll have to cough up the cash for a true Cummins LP. Anyone have the latest part #'s? The latest #'s in the Sticky are from 2007, I think.
I just ordered all the parts for the piston pump from the local komatsu dealer.
I used all the Komatsu part numbers from the sticky and is roughly about the same price. He said all the parts had to come from the Kentucky warehouse.
I ordered another spacer and gaskets today from Peterbilt, they're getting them right from cummins.
Old numbers still good, New numbers that were bolded in the sticky did not come up from CUMMINS.
3914284 on the spacer. The extra 1's at the one get cut off. Its only a 7 digit number like most cummins stuff.
After reading the later posts, I'm wondering if I should cancel my order too!!
PapeCat - have you used this pump personally and vouch its the lower pressure pump?
When I asked the guy at OFI if it was the low pressure pump, he said yes, but did not seem to sure of it. I just didn't get a good feeling about it, and the part #'s didn't cross reference. I don't want to risk pushing out the seal with the wrong pump, just to save a little money.
You know guys, the PN is the PN... I've got 2 on order so I guess when they arrive I'll let you know.
The only way to REALLY know would be to open the bugger up and look to see if it has the smaller piston and sleeve inside with the smaller spring.
j/k
They have the spacer too for $18.38, might as well grab one of those too......
So Mike got the two lift pumps we ordered and I had him take one apart and he says there is a Brass sleeve. I fwd'd him the link where there are pics of the two side by side sjust to confirm but it looks like we got the correct pump.
Still waiting on the tubes.
