Lift Pump
Lift Pump
Hi all,
I want to change my stock lift pump over to the piston style pump(3936320). I am having trouble locating one. Can anyone give me some help where to find one. Other than Dodge. Thanx.
The stock lift pump will barely keep up with a stock truck, and when you do pump mods, the fuel pressure can easily be pulled down to zero. With the low pressure piston lift pump, it puts out around 15psi at idle, and can support more than 400rwhp. I know guys with right around 400rwhp, that can't pull their pumps below 10psi.
It's also a good idea to install bigger fuel lines as well. Both of these mods will make a huge difference, even on a bone stock truck.
I just put a lift pump in a few weeks ago too. Next time.
a local komatsu dealer will get you one i even have part number 6732-72-1350 pump fuel transfer, 6735-71-6610 gaskets 2 required... i dont have the spacer number however. BE ADVISED!!!!! i have not installed this pump yet he crossed the low pressure cummins pump number so i am assuming it is a low psi pump.
