Leaking Getrag
Old Aug 31, 2012 | 12:11 AM
thrub's Avatar
Leaking Getrag
The rear seal on my get rag is leaking pretty bad. Can I just replace the seal or is something more wrong with it? What is the part number for the seal?
Old Aug 31, 2012 | 06:21 AM
bannerd's Avatar
I would give quad 4x4 a call;
http://quad4x4.com/
They should have a seal for that.
Old Aug 31, 2012 | 06:51 AM
gyman98's Avatar
It's pretty simple to change On a 2wd, maybe check your vent on the top too
Old Aug 31, 2012 | 08:15 PM
Exekiel69's Avatar
You can just remove the yoke 1 3/16" I think, then drive a drywall screw on two sections of the seal ring pull the seal out, clean well the area and install a new seal (I use a little permatex black on the outer ring of the seal for good insurance some may disagree but works excellent for Me), make sure You check the yoke where the seal rides on see if there isn't a grove from the seal pressure on it.
Do not remove the tail housing as it contains the shims that keep the transmission together, maybe not so easy to put back with it being horizontal.
Old Sep 1, 2012 | 12:40 AM
thrub's Avatar
My truck is a 4x4 so not quite so easy as the transfer case has to come off?
Old Sep 1, 2012 | 01:12 AM
thrub's Avatar
where is the vent on top?
Old Sep 1, 2012 | 02:30 AM
Exekiel69's Avatar
Here is a pics from mine, it is a 89 version of the g360.
Now that You bring this up, I put a short vent hose with a cap on mine (not in this picture) since it used to leak oil through this vent when I overfilled it to 5qt, nice and dry now.
Old Sep 2, 2012 | 09:27 PM
thrub's Avatar
Was under my truck today and cleaned most of the gunk off the top of my getrag but could not find a vent in the position in the photo above. Is there other versions of the getrag that have a different vent location?
lilsuzuki4x4
Sep 1, 2011 01:50 AM
93John
Jun 29, 2009 11:09 PM
Exekiel69
Jul 21, 2008 09:52 PM
Monty
Jan 21, 2003 03:40 AM
Palmetto_kid
Oct 16, 2002 05:41 PM
