Leaking Getrag
Old Jan 12, 2003 | 11:51 AM
Monty's Avatar
Leaking Getrag
Hey fellas, how many running the Getrag 360 have small leaks? Mine looks like it is coming from the top cover and the tranny output seal. Seems to be worse when I overfill the Getrag by 1 quart like you should. How many have found the gaskets to replace them? How much? With almost 200k on the Getrag, that is its only problems.<br><br>BTW: I have looked at Standard Trans. site and some others. Good info, but it doesnt show where you can buy the individual gaskets.
Old Jan 12, 2003 | 12:33 PM
92RamCTD's Avatar
Re:Leaking Getrag
I just replaced the output seal on my transfer case if thats what your refering to. (knock on wood) no leaks from my trannie yet.
Old Jan 13, 2003 | 07:24 AM
Monty's Avatar
Re:Leaking Getrag
Well, mine's a 2wd. looks like the output/yoke seal is leaking on mine. Just wondering if anyone has had any luck finding a new seal for the Getrag.
Old Jan 13, 2003 | 03:20 PM
DJ's Avatar
DJ
Re:Leaking Getrag
Call the guys at Standard Trans, I bought a syncro and a couple seals from them. There prices were reasonable.
Old Jan 13, 2003 | 06:17 PM
Grey Wolf's Avatar
Re:Leaking Getrag
I've found if you overfill them they will pump the fluid out of the breather!
Old Jan 15, 2003 | 02:50 PM
CruisingRam2's Avatar
Re:Leaking Getrag
My getrag is making a very peculiar noise, like a bearing bouncing around inside the top of the tranny. It still drives and runs fine, but I am pulling the tranny and taking it to the shop as soon as I return from vacation. Any body have this problem?
Old Jan 16, 2003 | 06:13 PM
MNYPDRBLT's Avatar
Re:Leaking Getrag
I've got the same noise problem with mine ....Only in 4th gear pulling at lower r.p.m.'s though. Seemed to get a whole lot louder when I added the P.O.D.'s<br><br>I'm trying to figure out if I should tare this one apart, or put in a 4500 conversion...The conversion is a good bit of money but then I would never have to worry about my Getrag again!! It might be worth it!<br><br>Any thoughts?<br><br>Thanks
Old Jan 16, 2003 | 06:36 PM
Monty's Avatar
Re:Leaking Getrag
[quote author=MNYPDRBLT link=board=9;threadid=9543;start=0#92915 date=1042762385]<br>I've got the same noise problem with mine ....Only in 4th gear pulling at lower r.p.m.'s though. Seemed to get a whole lot louder when I added the P.O.D.'s<br><br>I'm trying to figure out if I should tare this one apart, or put in a 4500 conversion...The conversion is a good bit of money but then I would never have to worry about my Getrag again!! It might be worth it!<br><br>Any thoughts?<br><br>Thanks<br>[/quote]<br><br>Sounds just like mine. I installed the POD's in yesterday and now at low RPM's in 4th, it growls a little.
Old Jan 18, 2003 | 09:02 AM
Monty's Avatar
Re:Leaking Getrag
I called the guys at Standard Transmission. They have the output seal for $5.52.
Old Jan 18, 2003 | 09:22 AM
pappyman's Avatar
Re:Leaking Getrag
Check your seal ride area (yolk) for wear also if its worn you mite need a speedy sleeve to restore the sealing area
Old Jan 18, 2003 | 09:26 AM
Monty's Avatar
Re:Leaking Getrag
;DThanks for the tip Pappy.
Old Jan 18, 2003 | 03:24 PM
ZONE5AB's Avatar
Re:Leaking Getrag
Check for lateral slop in the output shaft when changing the rear seal. My Getrag failure started with a leak at the rear seal caused by excessive side movement at the shaft and quickly progressed to a full blown disintegration.
Old Jan 19, 2003 | 01:31 AM
2manydogs's Avatar
Re:Leaking Getrag
Mine is noisy in 4th at low RPM also. I have a feeling that because 4th gear is &quot;direct drive&quot; and none of the actual gears are engaged and are loose on the main shaft they are rattling against the counter shaft gears. Also, when I rebuilt it and installed a non-stock clutch disc, it had an annoying rattle at idle, supposedly due to the design of the clutch damper springs allowing the same thing at idle in neutral. Adjusting the idle to 900 got rid of it. It's still going at 266,000 (fingers crossed) Jim
Old Jan 20, 2003 | 05:08 PM
Re:Leaking Getrag
MIne has got to come out, it makes the noise in all gears as soon as the truck moves, but not with the clutch dis-engaged, so I know it is in the tranny. How much does swapping to the nv whatever cost?
Old Jan 20, 2003 | 05:28 PM
Monty's Avatar
Re:Leaking Getrag
[quote author=CruisingRam2 link=board=9;threadid=9543;start=0#94214 date=1043104098]<br>MIne has got to come out, it makes the noise in all gears as soon as the truck moves, but not with the clutch dis-engaged, so I know it is in the tranny. How much does swapping to the nv whatever cost?<br>[/quote]<br><br>http://www.standardtransmission.com<br>http://www.quad4x4.com<br>http://www.blumenthalmfg.com
