kdp tab?
Old Jul 12, 2005 | 07:16 PM
apwatson50's Avatar
kdp tab?
OK so I took my timing cover off to fix the oil leak and kdp. So what do you do to tab these. I called cummins for a tab and they said they pull the pin out knurl it up and loctite it back in. Well it was sticking out an 1/8" but I already hammered it back in. What should I do?
Old Jul 12, 2005 | 07:27 PM
BC847's Avatar
1st Generation Admin
See if you can get some ideas here: https://www.dieseltruckresource.com/...threadid=62932
Hope it helps.
Old Jul 12, 2005 | 09:16 PM
gman07's Avatar
I did the clothes hanger thing a while back, no problems yet.
Old Jul 12, 2005 | 10:03 PM
apwatson50's Avatar
cool thanks, I remembered that, I just made a tab out of a piece of a hurrican clip I had laying around, should work. Its not really stiff but should be enough. I also pinged the around the hole with a center punch. I OK with how it is now. I was amazed because the bolt right next to the KDP was only hand tight or loose as it were. That could have sucked a lot!!
Old Jul 12, 2005 | 10:51 PM
rebal's Avatar
i would just peen the open end of the hole it wont come out and you dont need to pull the bolt and tab it and loctite it
Old Jul 13, 2005 | 01:20 AM
janb's Avatar
where is the link to the 'fixture fix'
seems that might be good choice, since I have no other reason to pull off the T cover
Old Jul 13, 2005 | 03:46 PM
That's the official Cummins fix. Get a hammer!
bigragu
Feb 5, 2006 10:43 AM
blueberry
Nov 3, 2005 11:30 PM
Lil Dog
23
Feb 5, 2004 10:47 AM
Cumminsdude
Jan 4, 2004 11:56 AM
WTTD
Apr 23, 2003 02:08 PM
