KDP Kill
Just get the front crank seal and peen the pin in. I have had good success reusing the cover gasket, it sticks to the cover like stink on poo and a bead of RTV will seal it to the case.
Let me know if you want a hand, I'm probably less than an hour from you.
Okay, I'll be at Shady Maple tom so I can talk to you then, thanks a lot!
i just did mine this past saturday, took b/w 4-5 hours - its easy to do!
i got the kit from genos and wasnt too happy about it the guide for the crank seal was 1/8" too small and i couldnt get it on the crank so i had to get the oem seal from cummins and genos wouldnt refund me...i was a little mad about that
be sure to locktite and re-torc the 5 bolts holding the case to the block i had one bolt only finger tight! if you need directions look up TST dowl pin directions- very straight forward
E-Train
Jun 22, 2007 12:19 PM
CACalomino
22
May 5, 2007 08:55 PM
Hes in Eastern PA
Hey great idea!
