Just got my truck running and need help
I just got my truck back togather and running I put head gaskets studs 60lb springs ats exhaust manifold twins(hx35/hx55) and some other small stuff and I got a used ip out of a junk yard and put on it. Now when I want to start it I have to use starting fluid to get it started but after its started it idles fine and runs good so what could be my problem? After I get it running I can shut it off and try to start it right back up and it still wont start with out starting fluid.
I agree...sounds like air. Check you oil level. If it's leaking out the front shaft seal on the IP then you won't "see" a fuel leak, but you could have one if your oil level is rising.
angrygoose
15
Jul 3, 2009 09:38 PM
mullishacrew
Apr 27, 2008 04:54 PM
Bobcat698
Apr 13, 2006 09:12 AM
