Junkyard Find
Old Apr 7, 2011 | 02:21 PM
1stgenCTD92's Avatar
Junkyard Find
I found a getrag and 205 t-case in a cummins. Guy wants 450 bucks for everything. The trans is stuck in 5th gear and they broke the shifter off. Just wantin to know what you guys think about it.
Questions;
Why is it stuck in 5th, how easy is it to get that shifter out, and how much would it be to just rebuild the trans while its out?
and the T-case needs a gasket kit for sure.
Old Apr 7, 2011 | 06:16 PM
simplysmn's Avatar
Grab it you could almost double your money on it easy
Old Apr 9, 2011 | 02:05 AM
Could be seized. If the guy ran it low on fluid and was cruising in 5th when everything finally got too hot.
I saw a Getrag that had gotten so hot it actually melted the aluminum shift forks......
Old Apr 9, 2011 | 07:55 AM
ARbowhunter7's Avatar
That's a good deal...I need a T-case. I've been scouring the parts networks and I can't even find a good used T-case by itself for $450
Old Apr 9, 2011 | 08:18 AM
Jer12377's Avatar
From: North Haven,CT "Living in occupied teritory" & Barton,VT
GRAB IT! $350 for all the bearings, synchros, seals and gasket (eBay) in the trany and all gears and shafts are available. I rebuilt mine myself in my basement and its going on 3000 miles since the rebuild. I forget how much they want for a rebuilt one but, I'm sure its more than $1000 and you'll have less than that in the whole tranny and t-case. My $0.02.
Old Apr 9, 2011 | 08:53 AM
307Kenworth's Avatar
T Case is worth at least that
Old Apr 9, 2011 | 09:47 AM
Trebor's Avatar
IIRC, Zbag sell them on car-part.com for $750 reman with a warranty.
Old Apr 9, 2011 | 11:39 AM
Mark Nixon's Avatar
Yep, saw that.
Best place to buy them from, IMO.
Locked in 5th could be as simple as the tranny got loose and the shifter got jammed between 2 gears, remove the shifter stub, take a large screwdriver and try to slide the shift rails back in place.
OR it could be ran dead dry on oil and siezed in 5th, at which point a simple re-bearing and seal kit is not likely to fix it.
If they run that dry, count on the mainshaft-gear cage bearings being fried, shafts and gears being galled, synchronizer hubs being blue from heat and even a cluster shaft being broken.
At any rate, snag ALL of it, flywheel, pressure plate, hydros, pedals, T-case, bellhousing, WIRING HARNESSES (how many people think of THOSE?), even the steering column if you can afford to.
Mark.
1st gen wontabe
Aug 19, 2010 01:09 AM
stillsmokin
Dec 7, 2006 02:53 AM
ruquik
Jul 27, 2006 11:43 AM
