Intercooler & AC Question
Hey guys, to start off I'd like to say I've been creeping around this site and decided I would join after all the useful info I've found here! I've looked and looked but haven't found the answer I'm looking for.
So my first question is, on the factory 1st gen intercooler one of the AC condenser mounting studs has been broke off, and I would like to repair it before fixing my AC. What is the best way to remove this stud, use an easy out? Or put a wrench on the shoulder and turn it out that way? I am going to soak it in penetrating oil all week and try to remove it next weekend.
Question two. I am trying to put AC back on my 91 W250, it was factory AC but the original owner removed the compressor due to the clutch locking up. So I knew I wouldn't have every part I needed (like the back half of the compressor bracket), I do have everything else I believe. As I looked at numerous forums here and found a "sticky" thread by maybe368. He shows these nylon looking alignment pins that go through the gasket from the lines to the compressor. I know I do not have these and I was curious as to do I need these? Do they serve any other purpose other than aligning the lines to the compressor? And if I do need these where can I get them?
Thanks for any info or insight you guys may have.
Joel
Joel
They insure that the crush zone of the gaskets are in the correct place. The automotive ac shop by my house has them in a bin behind the counter, so I am sure they are ez to find...Mark
They must be pretty common, because the guy took 1 look, spun around and got them out of a bin. I think I may have an old 1, I'll try to find and measure it...Mark
I think those plastic inserts are all the same.
As for the broken mounting bolt it screws into the I/C which is aluminum so use a wrench and work it back and forth if it doesn't want to come out.
If you had to and you are really careful you could heli-coil it.
Thanks Mark, I'll check around here at the local parts stores and see what I come up with. I know I got some with my new expansion valve, so I checked the compressor box and there were none in there. The ones for the expansion valve were different diameters but didn't see if they were the same thickness.
And Johnny, that is one of the studs, not sure if it matters. And you mean put a wrench on the oval looking piece with the two flat sides?
Joel
Joel
Joel
Joel
http://www.carparts.com/details/Dodg...L/FS38849.html, which I assume is the one you already have. I'll go by the ac shop by my house a little later and get the part number for you. Or PM me your address I'll send them to you...Mark
Yeah Mark those are the only one's I have. I'm gonna check here locally. And that part number may help. I'd like to get them locally to keep from the hassle of shipping and all. But if that's what it takes to get them, then I'll do that. I appreciate all help.
Joel
Joel
Mark, I have found them at my local CarQuest. They are called A/C pilots and the CarQuest part number is 207018. I appreciate all the help you've supplied. Thank you.
Joel
Joel
Mark, I went down to my local CarQuest today and they knew exactly what I needed. They are called A/C pilots. Part number from CarQuest is 207018. Thanks for all your help.
Joel
Joel
Cool, I tried to think of all the things they might be called, but pilot never came to mind. Glad you found the, don't forget the Nylog...Mark
