Installed 3200rpm spring,Egt high.
I installed my 3200 rpm spring today,I really like the improvement.I`ve made some pump adjustments and a hx-35,12.But now Egts go to 1300 under hard throttle.I was also pulling my 16ft trailor unloaded,it only weighs 1100lbs.What is the best thing to do about the Egts.My truck is a `93 dually auto,3.54 gears.
A timing bump will help EGTs if you have not done it yet. Also, now that you have more RPM, maybe the lift pump isn't keeping up at the higher engine speeds. If the lift pump pressure is dropping off it may affect the dynamic timing in the VE. You'd be losing advance just when you need it most, high RPM and full throttle. Throw a cheap gauge on and go for a drive, might be worth a look.
Yes it it a Wg housing,it will spool up to around 30psi with the WG hooked up.I`ve considered putting my H1C back on or switching the exhaust housing from my H1C to my HX-35.And I`ll put a fuel pressure guage on to check the fuel pressure. What is reccommended fuel pressure.
NoSparkplugs
Jun 30, 2011 11:38 AM
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
cumminsdriver635
Nov 29, 2004 04:11 PM
