Injectors question, 1st gen vs 2nd gen
Old 12-29-2010, 05:51 AM
ClassA4x4's Avatar
What are the differences between the stock 1st Gen IC injectors and those in the 2nd Gen's? Will I gain any improvement putting the 2nd Gen injectors in my 1st Gen?
Old 12-29-2010, 06:10 AM
Onemoparnut's Avatar
The spray angle is wrong and the threads where the fuel lines thread on are different also.
Old 12-29-2010, 07:47 AM
ClassA4x4's Avatar
thanks for the helpful info
Old 12-29-2010, 07:56 AM
G1625S's Avatar
And the pop pressure for p-pumps is much higher. Even if the bodies were swapped, the VE would not be a happy camper trying to pop them off.
Old 12-29-2010, 08:13 AM
What is the pop pressure on the p pump injectors?
Old 12-29-2010, 09:06 AM
JBradley500's Avatar
Location: A 5th dimension, beyond that which is known to man.
260-300 depending on what you're doing with the truck I believe.
Old 12-29-2010, 11:55 AM
dodgetrucker75's Avatar
how is the spray angle different? i know the injection line threads are bigger and the pop pressure is higher on the p-pump injectors, but the heads and pistons are the same
Old 12-29-2010, 02:10 PM
CaptainChrysler's Avatar
NonI/C is 155* and IC is 145*, IIRC.
BRUISER
02-02-2015 11:25 AM
77machomopar
07-15-2009 04:56 AM
Bo-man
08-11-2007 08:08 PM
59FORD
08-07-2005 10:15 AM
RedRotors
06-22-2005 07:12 PM
Quick Reply: Injectors question, 1st gen vs 2nd gen
