1st gen injectors on an 2nd gen ?
Old Jun 20, 2005 | 12:17 PM
RedRotors's Avatar
I would like to know if it will work propely ? They share the same injector body. I know it not the end of the world for the power, but i can have a set of 190hp for free, new.
Anyone ?
Thanks,
Marc/
Old Jun 20, 2005 | 12:22 PM
caleb c.'s Avatar
The pop-off pressures are diffrent.Not gonna' work to good.
Old Jun 20, 2005 | 12:33 PM
RedRotors's Avatar
I have a pop tester, so i can set the proper pressure.. So if it's just a matter of pressure i can easily fix it..
Cheers,
Marc/
Old Jun 20, 2005 | 01:01 PM
NeedMoPower's Avatar
They will require some modifications, but should work. I know you can take 370's, modify them, and install them in a 1st gen so you should be able to do the opposite. I'm just not sure on what all has to be modified.
Old Jun 20, 2005 | 03:27 PM
RedRotors's Avatar
Anyone got the pop pressure on the 2nd gen injectors ?
Marc/
Old Jun 20, 2005 | 04:43 PM
Jim Shulmister's Avatar
Muted User
The fuel line area is different. They will bolt right up to the head though.
Old Jun 20, 2005 | 09:24 PM
RedRotors's Avatar
As i said, if it's just a matter of changing the pop pressure, it's no problem for me.. I was just curious about the spray angle.. After opening a 190hp, it seems that it will match the 145* that we have on the 2nd gen.. Last thing i need to know is the pop pressure of the 2nd gen so i can match the pressure..
Marc/
Old Jun 21, 2005 | 12:15 PM
pmtg's Avatar
yep...the connection from the injection pump fuel line to the injector is different between the 1st and 2nd gen 12 valves. need the injector body from your gen truck or custom injection lines.
you could send in your injectors to company of your choice to change to the injector body with the correct fuel line connection.
plus pressures.
Pat
Old Jun 21, 2005 | 01:11 PM
RedRotors's Avatar
I have some doubt about it.. I have an 190hp 1st gen injector and a Bosch 300hp ( for the 2nd gen ) and the are EXACTLY identical, except that the Bosch 300hp is rated 262bar and the 190hp rated 300bar. The fuel line connections are identical, they have the same body type ' KDAL59 P6 '.. The only difference is the nozzles and the pop pressure..
Marc/
Old Jun 22, 2005 | 11:54 AM
vssman's Avatar
Going from memory...
The only physical difference between 1st and 2nd gen injectors is that early 1st gen injectors use a smaller diameter nozzle. The rest is the same physically. Don't know about the pop off pressures.
Old Jun 22, 2005 | 05:47 PM
pmtg's Avatar
Marc/
its a good thing i put that disclaimer in my sig
i must be getting confused with other random thoughts floating through my mind. my fault, sorry!
Old Jun 22, 2005 | 07:12 PM
RedRotors's Avatar
I didn't see the disclamer.. np Gilles..
Marc/
BRUISER
Feb 2, 2015 11:25 AM
ClassA4x4
Dec 29, 2010 02:10 PM
77machomopar
Jul 15, 2009 04:56 AM
Bo-man
Aug 11, 2007 08:08 PM
59FORD
Aug 7, 2005 10:15 AM
