hx40 application question
Old Sep 28, 2009 | 04:01 PM
NO_SPRK's Avatar
so i can get an HX40 that has the right flange but it wasnt made for the 6bt engine. does anyone know what has to be done to put it on? i did a search and only came up with general hx40 talk
Old Sep 28, 2009 | 04:24 PM
If it has a T3 flange it will bolt right on. You may or may not have to reclock the housings to get everything lined up.
Old Sep 28, 2009 | 06:25 PM
NO_SPRK's Avatar
Sweet. Maybe flip the manifold?
Old Sep 28, 2009 | 07:51 PM
Don't see why you'd want to?
Old Sep 28, 2009 | 08:25 PM
NO_SPRK's Avatar
I don't want to but I heard on some ford cummins swaps you have to flip the manifold to get it to fit correctly
Old Sep 28, 2009 | 10:53 PM
Philip's Avatar
No reason to flip the manifold on a 1st gen for a HX40. You will need a 4" exhaust system.
Now have you done a IC swap on your truck. I don't see anything in your sig. You might have problems finding a HX40 for a boot connection.
Old Sep 28, 2009 | 11:07 PM
NO_SPRK's Avatar
Sadly no. I had a PS full aluminum cooler ready to go but times were tough and I needed to sell it. I was thinking of doing a custom cross over intake and W/M injection. It would be cheaper to fab that stuff up right now then an intercooler
Now my other issue is fuel. I think I'm pushing a lot of fuel for standard injectors (non-IC truck) and my pump isn't totaly maxed yet. Some guy was selling a 5 speed truck with an HX40 and stock sticks. Said it ran good. All I'm looking to do right now is tow and my poor little turbo is being beat and my egts are always high. I know I need a intercooler but I figure the hx40 and better crossover intake would help a lot.
Right now I have a 3inch downpipe then 3.5 all the way back. Would the 4 into 3.5 be that restricting?
Old Sep 28, 2009 | 11:35 PM
jimbo486's Avatar
there would be no point in a 4" DP if you're just going to reduce it back down to 3.5". if you have or get a 4" DP, might as well just build the rest of the system in 4". use flex pipe to go around the t-case.
Old Sep 28, 2009 | 11:49 PM
NO_SPRK's Avatar
Well I'd end up buying 4inch all the way back when I got the cash. Where would I get the flex pipe?
Old Sep 29, 2009 | 06:45 AM
93Fury's Avatar
Is it an E-bay HX40?
Old Sep 29, 2009 | 08:45 AM
Falcon1's Avatar
Say no to flex pipe, do it right and get the correct mandrel bent pipe!!!!!!
Old Oct 7, 2009 | 01:44 AM
NO_SPRK's Avatar
id rather not use flex pipe. what are the cons?
Old Oct 7, 2009 | 01:46 AM
peobryant's Avatar
Are you wanting a stack, or full system?
Old Oct 7, 2009 | 01:54 AM
NO_SPRK's Avatar
oh yeah and its not a ebay turbo. whats up with the hx40s on ebay with 3inch outlet!? dont hx40s only come in 4inch? was there a 3.5inch? thanks!
Old Oct 7, 2009 | 02:00 AM
NO_SPRK's Avatar
i want a full system. id just use the flex pipe to go around the t-case. maybe buy one of those cheap ebay systems for 270 bucks and buy or make a 4inch hx40 downpipe
jstone44720
Mar 4, 2011 03:31 PM
nvr-enuf
Oct 17, 2010 09:55 PM
Striper
May 30, 2008 04:16 PM
Hawkeye
Sep 23, 2003 08:22 PM
4xWriter
Aug 25, 2003 12:27 AM
