How much fuel pressue?
Old Feb 17, 2008 | 03:29 PM
Montana2x2's Avatar
What should the fuel pressure be after the filter and before the IP with a stock lift pump? Thanks
Old Feb 17, 2008 | 03:48 PM
mopardamo's Avatar
Hello,
My 06 when stock has about 8 to 9 at idle and then runs about 9 to 10 running down the road. Wot it drops to 5. All is the same when the Big G is plugged in except the Wot drops to 0 after 4 seconds.
Damon
Old Feb 17, 2008 | 03:59 PM
BC847's Avatar
1st Generation Admin
Damon, the 1st gen lift-pump is an entirely different animal from the '06
Montana, the FSM is kinda vague in it's description of the performance characteristics.
- The minimum lift-pump output pressure is 3psi. Lift-pump output volume is 0.70qts per 30 seconds of engine cranking.
- To test the lift-pump, the FSM has you Tee a vacuum guage into the fuel line coming from the tank, and into the lift-pump. With the engine operating at 1500rpm for 30 seconds, the vacuum should not exceed 3.75" Hg. (If it does, look for a stopped-up fuel pickup).
- The maximum allowable pressure drop across the fuel filter is 3psig.
- If there's any fuel leakage on the exterior of the lift-pump, or you notice the engine lube oil level rising inexplicably, replace the pump.
Hope this helps.
Old Feb 17, 2008 | 04:55 PM
A healthy stock pump will put out 7 or 8 psi at idle.
Old Feb 17, 2008 | 07:17 PM
Montana2x2's Avatar
Thanks guys thats what I needed to know. Just installed a fuel pressure guage and new filter and wanted to know how much psi I was looking for. I guess my lift pump is in preyyt good shape. Thanks again
kwast
Jan 18, 2008 05:09 PM
ez_lle71
Aug 16, 2007 04:06 PM
Fireslo04
Jan 21, 2007 10:20 AM
Buckshotmckee
Feb 7, 2005 10:24 PM
