How long to install 3200 gov spring myself?
Old Feb 3, 2008 | 02:43 PM
pwrtripls1's Avatar
How long does it take? I have an extremely busy next couple days and only have a limited amount of time so I dont want to start tearing the VE apart and run out of time. I have most every tool I could need and work fairly fast.
Thanks.
Would I need to install valve springs if I decided to install the 3800rpm spring instead? Or would it be safe to run up to 36-3700rpms?
Old Feb 3, 2008 | 03:39 PM
Free89W350's Avatar
I would say give yourself at least an hour to make sure that your not rushing yourself. Just take your time and read the directions carefully. Then would be a good time to remove the lock collar on the fuel screw also, and you might want to take an cut a little bit off of the business end of the high idle screw that makes it easier for later adjustment purposes. When I did mine it took me about 45min but I was sort of rushing around.
Old Feb 3, 2008 | 04:48 PM
SuperiorRam's Avatar
it took me about 4 to 5 hours no valve springs it stops at 3000 rpm but fuels to that not like stock stops at 2000 and revs till 2500
Old Feb 3, 2008 | 05:49 PM
apprentice's Avatar
about two hours for me the pictorial tech artical really helped
Old Feb 3, 2008 | 07:14 PM
Be ready for it to take 4-5 hours. You will get it done much quicker if everything goes right.
Old Feb 3, 2008 | 08:08 PM
pred's Avatar
Lay a big white sheet under your truck before you start, This alone could save you hours looking for a "top hat"
HAHA,,,,,, Really, I always drop something.
Peter
Old Feb 3, 2008 | 09:31 PM
Caver Dave's Avatar
It only took me 1 hour...
with Jeepuller assisting & McMopar servicing the tranny!
I agree with having the pictorial guide (in the stickies) on hand.
Old Feb 3, 2008 | 09:50 PM
TJE's Avatar
TJE
I'm Mr. slow. It took me 1.5 days. I ran into a little trouble, caused by a lack of the proper tools. Good luck, it isn't that bad, Tony
Old Feb 3, 2008 | 10:04 PM
BC847's Avatar
1st Generation Admin
I second tucking an old sheet around the IP such that anything dropped is right where it can be picked up.
Old Feb 3, 2008 | 10:57 PM
56speedy's Avatar
"Lay a big white sheet under your truck before you start, This alone could save you hours looking for a "top hat" times 2 i lost mine speedy
Old Feb 3, 2008 | 11:11 PM
GO OVRIT's Avatar
I did it in about 45 min or so today. It wasn't nearly as bad as I thought it would be. I can see where the tophat could get lost pretty easy. I wedged a straight screwdriver against the tophat and put the other end of the spring on first. Then I had both hands to hook the end to the tophat. I can't believe how much of a differrence the spring made. I'm impressed $15.00 did that.
Old Feb 3, 2008 | 11:44 PM
cell's Avatar
Mine was installed today as well, took about 1.5 hours, but had to re index the throttle, which was actually the trickiest part. WOW, I have to say it drives sooo much nicer now.
Old Feb 4, 2008 | 03:46 AM
Jim Lane's Avatar
Whenever I work on my engine I will stick a large rare earth magnet near where I am working so I can stick all of the small parts and bolts to it so they do not fall into the engine or I will use one of my magnetized bowls for the parts.
I will also set up some strong lighting in the area usually around 500 watts so to avoid a lot of shadows.
As you probably know I will photograph the procedure as I go so I can always go back and see how it was and have a note pad and sharpie ready for any notes or reference marks.
The sheet under the truck is a good idea especially if you are working on a gravel driveway.
Starting out by cleaning your engine compartment beforehand also makes it easier so you’re not covered in oil while lying across your engine.
Jim
Old Feb 4, 2008 | 07:48 AM
Caver Dave's Avatar
Cell, explain why you did this! Guessing it was address idle issues?
Since twisting in my fuel screw, the idle has been very high. I know it'll take another turn (or 2? ), but I can't get the idle down.
Re-indexing the the arm on the throttle shaft was recommended as a possible resolution, just haven't had time (OK, I'm waiting on warmer temps in the driveway... can't get the dually in my garage )
Old Feb 5, 2008 | 12:51 AM
cell's Avatar
Yeah, it idled really high after the spring install, https://www.dieseltruckresource.com/...d.php?t=115833 has a lot of information about indexing.
DarrinGT
Jan 8, 2008 08:12 PM
fishin fever
Mar 13, 2006 06:46 PM
adamroofer25
Jun 28, 2004 03:36 PM
Tommy93w350
Jan 30, 2004 10:30 AM
Jim Shulmister
Mar 8, 2003 09:07 AM
