Whine in 4wd
Old Feb 4, 2008 | 01:05 PM
pokeypennell's Avatar
Whine in 4wd
I have noticed lately that when I have the truck in 4wd, that something in the front is whining, it doens't do it in 2wd. I am wondering if its the transfer case?? any thoughts??
where is the bolt that i can check the fluid level, and what fluid does the T-case take? (im assuming its separtate from the trans fluid)
thanks
Nick
Old Feb 4, 2008 | 01:09 PM
tha89sx's Avatar
transfercase takes atf.
bolt in on the back of the transfer case, you can see two of them from underneath the truck looking from between the diff and the case.
top one is your measurement, just like a differential.
Old Feb 4, 2008 | 01:16 PM
So any trans fluid? Thats easy, I hope its just low, it tends to make the whine only on deceleration...if that means anything.
What model Trans case do i have, its a 1990 auto with a 727.
Old Feb 4, 2008 | 05:36 PM
CaptainChrysler's Avatar
Stock transfer case is a NP205. It should have 80-90 gear oil in it.
Mine was making some noise and it turned out the flange for the front driveshaft was loose. It has a locking nut on it. I removed the nut and cleaned it up good. Put some dimples on the end that locks it and applied Locktite, torqued it down real good. It was alot quieter. Keep in mind they make some noise in 4x4.
Old Feb 5, 2008 | 07:34 AM
So it takes 80-90w not trans fluid....this is my first 4wd so I was unsure of the potential for making noise. I will check that fluid, it only whines when you let off and are slowing down...hopefully itf just low.
Old Feb 5, 2008 | 11:43 AM
MoparMarv's Avatar
The service manual has a list of all the different kinds of grades of gear oil. I think I used 85W140 with was recommended for severe duty. I think noise in 4wd is just the nature of the beast. Mine has a loose front flange that I need to tighten up but have yet to get around to it.
93Fury
Mar 31, 2010 01:33 PM
wrangler04
Jul 17, 2007 11:00 PM
VikingDiesel
Competition / Pulls / OffRoad
Dec 29, 2006 07:17 PM
95black2615
Dec 20, 2006 06:37 PM
1320
May 6, 2003 06:30 PM
