Hotwired KSB good or bad?
with many threads saying its bad to hotwire due to dropping case pressure then some say it increases it what is really going on here is it a good thing or a bad thing? yes i understand at idle no good but using it at rpm does it negatively affect the IP's life span or injectors? i have mine on a switch and use it every once in a while if racing or pulling a hill but never really below 1500rpms. you can deffinately hear the timing rattle when its on.
A hot-wired KSB will help keep the case pressure up so you don't loose the dynamic timing under WOT conditions. It generally won't hurt anything when used on the occasional dyno/drag run and such.
It also depends on which KSB set up you have. Early KSB's got power with the engine hot; later ones got power to it with the engine cold. OK to do the early ones for full time operation which is just bypassing the temperature switch, generally bad to do the later ones because of the case pressure issue.
440_D50
Jan 21, 2007 09:35 PM
