How bad is it to run without the KSB hooked up?
Just as said above. I just bought a 93 and didn't notice it at the time, but the KSB isn't hooked up. I couldn't even find the wire that went to it. It still starts and shuts off fine, but could something bad be happening because of this???
I'm gonna tear into it soon and find out what's going on with the wiring, because there's other funny stuff going on as well. Hopefully I didn't get myself into a nightmare...
The KSB is controlled by a temperature switch in the intake that activates it when the intake temp is below a certain value. What it does is increase the internal pressure in the pump so the timing is more advanced when the solenoid is active.
Having it unhooked won't hurt anything.
Thanks guys, that takes a little worry out of it.
Smoky Beast, what I think one of them said before is that it advances the timing when it's energized, so if it's unhooked, no advance...
440_50, that is correct but only for IC trucks
Smoky Beast, when the non-ic is unplugged it gains an advance by raising the case pressure in the pump. it also gives the equivalent to a lot more than an 1/8th bump. it is not a recommended way to gain timing.
big stinky
Nov 1, 2014 03:22 PM
JaimeG
Mar 26, 2009 06:58 AM
BRUISER
Jan 18, 2009 02:28 PM
Nothing to worry about.
