Honing injectors
Honing injectors
I'm wondering how much more power(fuel) is to be had by honing pod's? As I've stated elsewhere, smoke doesn't bother me, and the HTTB2 should be good for burning a bit more fuel. It seems that honing would be a cheap alternative to shelling out big bucks for new injectors. Thoughts?
I'm guessing they could be honed out, but other probs will come into play. By enlarging the bore it will let more fuel thru but fail to atomize it as well, that means drastic smoke, not much more power, lower fuel milage not to mention egt's thru the roof that your turbo cant help cool off. More fuel is only advantagous if its in vapor form, just squiting liquid in wont get you the HP the same amount of vapor will. As a rule EDM'S are the way to go, they atomize a lot better.
Old Smokey made 600+ with a set of honed POD's. I wouldn't hone used tips. They have a tendency to fail/break. Best bet is to sell your old POD's and put that money towards something new.
I would ask the shop doing the hone job if that low mileage would be ok.
www.scheiddiesel.com will make some hot EDM's for you at a cheaper rate than most 'hot' injectors I've seen advertised online.
Sinbadd
Jun 17, 2008 06:38 PM
rockittboy
Jan 17, 2006 09:14 AM
