HELP!!!!!! Runaway issue
Old Aug 12, 2007 | 10:27 AM
dan1stgen's Avatar
twaeked pump now when i touch accelerator rpms rise w/o me doing anything cant' seem to adj. back to where it was happened after i adj. fuel screw on back of pump???????? it will idle just can't touch the throttle should i back it off more or will this in turn cause more issues? what happens if i back it all the way out then slowly tun it in?
Old Aug 12, 2007 | 10:42 AM
rbrettctd's Avatar
You did back it to where it was before the runaway? Check here. https://www.dieseltruckresource.com/...d.php?t=158962
Old Aug 12, 2007 | 10:57 AM
dan1stgen's Avatar
perfect so i can't back it out to much rite, i lost my point of reference but am close? and yes i got a back shutdown for my intake in case of a real back runaway.
Old Aug 12, 2007 | 11:07 AM
rbrettctd's Avatar
Try turning it back just a 1/4 or 1/2 turn and keep going till it returns fine.
Old Aug 12, 2007 | 11:13 AM
dan1stgen's Avatar
well i turned it down like 3 turns and it wouldn't idle or take off weeewwwww finally!! so then i just slowly turned it up and it leveled off, i kept snapping the throttle and man its like a bullet now i just know im gunna throw a u-joint need to get them spicers.
thanks for all your help and that link was just what i needed.
Old Aug 12, 2007 | 11:18 AM
rbrettctd's Avatar
No problem. As for u joints youre fine. I was running pods, 3 turns on fuel screw,fuel pin, etc., i.e. loads of power, on original u joints with no problems.
Old Sep 9, 2007 | 11:21 PM
Canadian24v's Avatar
I'm having a similar problem and i figured it was cause i turned the power screw to far. I tried to turn it back but its stuck and now the head is chewed up to pull it out. I tried double nutting it but couldn't get a wrench on the inner nut to turn it. Before i mig a nut on the end does anyone know if you can buy a new screw seperately from an injection shop.
Old Sep 9, 2007 | 11:26 PM
bgilbert's Avatar
Yep, call www.scheiddiesel.com or a good Bosch shop. The part number for the screw with the 6mm hex end instead of the slotted end was on here awhile back.
Edit: found it via 1stgen.org: Alright, the part number for the full power screw is 1-463-402-423(-000). It costs $20. But I'm not sure if it's the part number for the hex end screw.
Old Sep 10, 2007 | 09:12 AM
thank you very much.
xzaq103
Oct 20, 2008 10:00 AM
Paul Winey
Apr 23, 2008 01:47 PM
Free89W350
Apr 24, 2007 12:33 AM
smokinrod
Jan 12, 2007 12:37 AM
Zackb911
Jun 21, 2006 09:09 AM
