Help Leaking Fuel Pin!!!!!!
Help I pulled my AFC diaphragm to adjust my star wheel before I head to Mn. for a week and there is fuel under my diaphragm I don't have time to tear the pump apart tonight and I am leaving a about 5 am tomorrow will it be ok for the trip?
Thanks
Curtis
Thanks
Curtis
I just did mine because I went to put my 3200 spring in and when I popped the cover it was fuel of fuel. I had to go in there anyway so it wasn't a big deal. I don't think it will hurt anything. You don't know how long it's been that way and you've been driving it, right.
White smoke could mean air in the fuel system. Also to replace the fuel screw o-ring You just need to remove the screw and replace the little o-ring as far as I remember.
As long as it's not pouring out the vent it will be OK.
well I tore into it tonight and I found a cupped washer under the o-ring retainer that wasn't mentioned in the sticky does any body have any idea if it is supposed to be there?
thanks Curtis
thanks Curtis
Yea, my old non-ic pump didn't have it but the intercooled pump did. The piece that the pin rides through is machined to accept the little cupped washer on the newer pump. I was going to use it on my non-ic but of course it wasn't machined for it so it no go.
gaberichison
12-21-2014 12:21 PM
Cowboy_Customs
10-18-2011 01:46 AM
PeytonMaterne
08-11-2008 05:25 PM
