He351ve?
Old Jun 29, 2009 | 10:11 AM
JW's3Dodges's Avatar
He351ve?
Is the VGT turbo off the 6.7L's any good? Why couldn't you remove the electronic wastegate actuator and block it off to make a non-wastegated turbo? Is the actuator the only thing that makes it non-desireable? These turbo's seem to be plentiful and CHEAP.
Old Jun 29, 2009 | 01:04 PM
soggy's Avatar
you can do that, the other thing is they have an oddball flange, so you'll need to figure out an adapter from manifold to turbo.
Old Jun 29, 2009 | 01:58 PM
sdubfid's Avatar
It doesn't have a wastegate, the actuator controls the vanes on the exhaust side. You could set it up to your desired exhaust housing size and just leave it. They are good turbos.
Old Jun 29, 2009 | 03:18 PM
speed75's Avatar
i have one yet to put it on what is the exhaust housing size full open
Old Jun 29, 2009 | 03:57 PM
Sdubfid, explain to me how the actuator controls the vanes. I'm not doubting you, just want to understand how it works. Also, X2 what speed75 said about the housing size.
Old Jun 29, 2009 | 04:23 PM
apwatson50's Avatar
Do a search on here, the 2nd gen forum specifically, there are a couple people who have done the conversion and documented it. But they basically used a normal wastegate actuator or just some type of spring to control the vanes. So basically you're using the drive pressure pushing against the vanes to open them and the spring to counteract the drive pressure. So you really have to play around with different spring rates to get it right. Also If I remember right the volume can go from something like 6cm to 23cm, so its a pretty large range.
Old Jun 29, 2009 | 05:00 PM
c12h26 has a 91 d250 ve pumper he put a 6.7 turbo on. pm him
You should hear it when he opens the vains. Oh my god it'll hurt your ears.
I don't know the compressor wheel specs on it and stuff. yet
Old Jun 29, 2009 | 05:21 PM
sdubfid's Avatar
Here is a video on the he351ve variable. Yes it is something lioke 5cm full closed to 25cm full open approximately from what I have read.
http://www.youtube.com/watch?v=y9bi3hTaFUA
That means you could just set it and forget it to say a 12cm housing if you wanted. Some guys are controlling the lever with a wastegate actuator. The more boost you build the more the vanes open reducing your drive pressure with increasing rpm. It would be primitive but I think it would work good. When you are off the throttle it would probably work like an exhaust brake as well if you set it up so 0psi= fully closed.
Old Jun 29, 2009 | 05:26 PM
apwatson50's Avatar
If you did that and had the spring loose enough to where it would spool, it probably wouldn't stay closed to actually work as an exhaust brake. As exhaust brakes make upwards of 40-50psi of back pressure during braking. So you would need something else that would force the actuator closed to do exhaust braking. IMHO
Old Jun 29, 2009 | 05:30 PM
speed75's Avatar
i would think if you used a waste gate actuator it would open good with boost but if you let off gas quick it would bark preety bad
Old Jun 29, 2009 | 05:42 PM
apwatson50's Avatar
Only one way to find out!
Old Jun 29, 2009 | 08:15 PM
The_Head's Avatar
heh heh, I bought one of these last week. $100. I'm going to sit on it for awhile and see what happens.
Old Jun 29, 2009 | 09:17 PM
Great discussion and great tech advice. I think I'll pick one up and do like The Head, sit on it for awhile and learn some more!
Old Jun 29, 2009 | 09:24 PM
https://www.dieseltruckresource.com/...e-t245625.html
check out this thread
Old Jun 29, 2009 | 09:44 PM
Thanks Crossy's son. I forgot I read this post the other day. My head's been spinning trying to learn & remember all the different turbo's. Sorry for duplicating c12h26's subject but this has still been a good discussion!
c12h26
Jan 13, 2011 03:00 AM
evil06sti
19
Jan 7, 2011 11:07 AM
stoneagemaxx
Sep 28, 2009 11:08 AM
recklesskelly
Aug 30, 2009 06:21 PM
oly_fab
Apr 13, 2009 08:44 AM
