Got the HE351VE on
Got the HE351VE on
Got the HE351VE on the truck today and made some test runs in the full open position,the roads were wet so at a 50 mph roll when the boost came up at 60 mph it broke the tires loss spinning. max boost was 32 psi and the drive was 45 psi, EGT's never got over 1600*. With the baby H1C max boost was 23 psi drive was 40 psi and the EGT's would go well over 1800*.In the full closed position at an idle the drive will go to 15 psi and sounds like a jet taking off.
Here are some pics and videos of the new turbo
http://www.youtube.com/watch?v=S33IDPbQcck
http://www.youtube.com/watch?v=H67txNw_U-w
wow! soundsl ike a ferd 6.0 power stroke when you started it up like that!!
Are you going to have a cable in the cab to control the VGT?
lookslike it makes it easier to stick a 4" DP in there as well.
Its about time someone put one of these on. Are you going to leave it manual where you like it best or control it with a wastegate actuator?
The ve is variable on the exhaust side.
Very cool!
I have been trying to figure out a way to use this turbo. It seems you can get them pretty cheap.
The exhaust brake function is the only time the turbo is all the way shut correct?
Do you think that perhaps just finding one setting for 99% of the time will be good enough. Something equal to having a 14-16cm housing perhaps?
I think the only real thing to worry about is over speeding the turbo correct?
I would have thought that someone would have come out with a stand alone controller for these things already....
keep up the good work. I might need to pick one of these up too!
