he351ve rebuild info???
Old 04-30-2009, 11:54 PM
evil06sti's Avatar
hey everyone.....by any chance does anyone have a recommendation for a place to buy a rebuild kit for the he351ve vgt? someone told me to use the reg hx35/40 kits, but i want to make sure....thanks
Old 05-01-2009, 01:52 AM
Zeus1987's Avatar
would a low miles used one work ? bits and pieces can be had all over ebay.
Old 05-01-2009, 12:17 PM
ShibbyEng.'s Avatar
for the price of the rebuild kit alone, you could get a good used one off ebay. And unless you have the means and procedure to properly realign the VGT slide after taking it out I wouldn't even try it if I were you. (there are special gauge pins to get the slide realigned inside the turbine housing appropriately, but those only work right if you index the driver gear properly after reinstalling it)
Old 05-01-2009, 05:12 PM
evil06sti's Avatar
oh i have completely disassembled it already (pics here-->http://photobucket.com/evil06sti) ....and its pretty straight forward.... i just want to know if it uses the same bearing kit as the hx35/40......
Old 05-01-2009, 05:52 PM
HotRodTodd's Avatar
You didn't bead blast the turbine wheels I hope. The one in the picture looks like it had been when cleaned up, hopefully its an optical illusion.
Old 05-01-2009, 06:45 PM
evil06sti's Avatar
oh no no !!! nothing was bead blasted...... i just used a small piece of scotch-brite to wipe off the soot......every thing else was wiped with a towel.....
Old 05-01-2009, 08:18 PM
Tree DR's Avatar
What's the reason for the rebuild?
Old 05-01-2009, 10:32 PM
evil06sti's Avatar
cause i bought it used and id just like having the piece of mind knowing the internals are fresh......its just more of a precaution
Old 05-02-2009, 01:08 AM
Zeus1987's Avatar
i googled "HE351ve rebuild" and found this little bit of info. dont know if it is accurate or not.
best part about this turbo is.. its VGT yes.. but it uses the same rebuild kit as a hx35/hx40 and uses the same turbine wheel as a hx35 on the cold side
Old 05-02-2009, 10:25 PM
evil06sti's Avatar
that would be sweet!!!
Old 05-03-2009, 02:18 AM
Zeus1987's Avatar
So some of the parts from the HX35/40 do seem interchangeable with the HE351ve, although if you need spare parts you can find a HE351ve on ebay for cheap and a HE351 for even cheaper. keep us informed on progress and pictures are always a plus
Old 05-03-2009, 02:47 AM
evil06sti's Avatar
www.photobucket.com/evil06stibuildup . . . here ya go .... and i think i may buy another he351 for parts...... but ill grab a hx35/40 kit and see what parts can be swapped
Old 05-05-2009, 12:38 PM
evil06sti's Avatar
well i decided to visit my old job (machine shop) and made a anti-surge mwe ring to replace the silencer ....take a look
Old 05-05-2009, 01:05 PM
ShibbyEng.'s Avatar
neeto, let us know how that sounds when you get it in.
Old 05-05-2009, 02:00 PM
evil06sti's Avatar
ill take a vid =)
Quick Reply: he351ve rebuild info???
