Grease or rust on fuel pin?
Old May 23, 2006 | 08:10 AM
flashgordon's Avatar
removed the top so that i could adjust the star wheel last night and when i removed the fuel pin it looked like.....well greasee rust!
I wonted to wipe it of but didn't now what type of lube to put back on it so i just turned the star will down a 1/4 and put it back to gether!
Any sugestions
Old May 23, 2006 | 09:27 AM
G1625S's Avatar
I use di-electric grease with good luck. Some have used anti-sneeze, but that stuff is just plain nasty when you get it on you and the AFC isn't exactly a high heat area, relatively speaking.
Old May 23, 2006 | 06:52 PM
I use a little dab of chassis grease (which in my case means Mobil 1 grease).
Old May 23, 2006 | 11:30 PM
Boatnik's Avatar
I just squirt some silicone spray lube in where the top banjo bolt attaches. Seems to do fine so far.
Old May 24, 2006 | 08:56 AM
Thanks guys, i'm glad that i'm not the only on that thout the grease in there needed replacing!
Old May 24, 2006 | 05:05 PM
All that is going to do is make a mess on top of the diaphragm.
Old May 24, 2006 | 05:11 PM
What a bout a boat grease?....if theres boost theres got to be condensation so moisture could get in and cause rust problems!.............Never mined my mined just caught up the moister or boost couldn't get there unless there was a tair in the dyafram,and the moister would be the least of the problem
gaberichison
Dec 21, 2014 12:21 PM
Cowboy_Customs
Oct 18, 2011 01:46 AM
Forty-Two
Oct 22, 2008 11:55 PM
Geico266
Sep 14, 2007 10:47 PM
bigragu
Oct 17, 2005 04:07 PM
