Getrag Problems
Old Jun 12, 2005 | 06:51 PM
cummins1279's Avatar
Question Getrag Problems
I'm looking at buying a '93 W250 5spd. I've heard that the NV4500 is a better trans. What problems does the Getrag tend to have and what is the life span compared to the NV4500?
Thanks!
Old Jun 12, 2005 | 08:31 PM
edwinsmith's Avatar
I dunno. I've heard of problems with the Getrag being weak and also heard the space between 3rd and 4th is to far to give good performance. The 3200 RPM govenor spring is supposed to cure the spacing problem but supposedly the engine was detuned because the Getrag wouldn't hold the added torque.
I figure when/if mine goes out I'd deal with it then but the conversion cost is to high right now.
They also say that it should be filled with a good 5W30 synthetic oil and overfilled by one quart which will help with the lifetime.
Edwin
Old Jun 12, 2005 | 08:43 PM
frostie's Avatar
I believe the bearings go out in the getrag. I have removed 2 of them, my 2WD truck got a 6 speed and my 4WD truck just got an NV4500 a few weeks ago. My 2WD truck knocked out the getrag after I started putting close to 300 HP to it.
My 4WD truck is only putting out, Im guessing 200, HP and it couldnt take it.
My 4WD truck had 272K on it though.
If you dont crank up the engine much It may be OK for a while
Good luck
Old Jun 13, 2005 | 07:57 PM
The main weak point is the input shaft bearing. Overfill by a quart to keep it lubed and the trans will do OK. Mine is holding up OK, and Stomp (the 1st gen HP god) is still running a Getrag. They aren't tolerant of abuse, but if you apply the power smoothly they will hold plenty.
Old Jun 14, 2005 | 05:03 AM
bgilbert's Avatar
huh?
Old Jun 14, 2005 | 04:21 PM
607 HP with a VE pump qualifies you for the HP god position, doesn't it?
Old Jun 14, 2005 | 04:40 PM
bgilbert's Avatar
I'd definately say Stomp is a god, but not the only one , don't forget Brian Block with 627hp VE pump #2 only.
Old Jun 14, 2005 | 05:00 PM
Wow! I hadn't heard about that. That's with one of those "big head" pumps I assume?
Old Jun 14, 2005 | 09:24 PM
mhuppertz's Avatar
Dang! What the ___ is a big head pump? and how could you ever get near 600 ponies with a VE on pure #2?
Old Jun 14, 2005 | 09:35 PM
mhuppertz's Avatar
Even overfilling the Getrag won't help pulling heavy up a hill on the freeway. The oil holes are too small to keep it cool. Makes a really gross sound when the input shaft bearing burns dry!
SQUEEEEEEEEEEEEK!
Old Jun 15, 2005 | 07:29 AM
bgilbert's Avatar
Yep 14mm head and rotor VE pump, same as big bad Mr. Stomp.
Old Jun 15, 2005 | 08:12 AM
apwatson50's Avatar
Didn't Stomp have a custum KTA head made?
Old Jun 15, 2005 | 11:17 AM
Alec's Avatar
KTA's real name is Brian, and I think his last name might be Block . . . My understanding is that Brian had a run of those heads made, and sold them to anyone who would pay the $400 or so that they cost to be manufactured (Old Smokey was on that track too, and I think they may have ended up combining forces). I think that if there is enough demand, he could and would have another run manufactured, but I believe that all of the original run have been sold. They have a larger diameter plunger (14mm vs. 12) and larger passages in the distributor head. I believe that they may be a reproduction of a discontinued head that Bosch had used on another application.
Regardless, I think that the Getrag can be nursed pretty well if kept full of oil -- I had not heard of problems with the input bearing running dry if the tranny was over-filled. You had that happen though, Mark?
Old Jun 15, 2005 | 11:24 AM
apwatson50's Avatar
What you just said, Alec, is what my understanding was.
DJ Turbo.
Oct 13, 2011 09:11 PM
MoparMarv
Aug 31, 2006 08:43 AM
yebatza
May 7, 2006 01:25 PM
yebatza
Apr 16, 2006 08:16 PM
TexasBlake
Feb 23, 2004 01:26 PM
