getrag oil change?
Old Dec 18, 2006 | 07:45 PM
Nathan's Avatar
I changed oil in my trans finally, I put the street L on it and it worked great, only thing is, anyone else who does this should know that it takes quite a long time laying under the truck and holding the quart bottles over you to pour it in. I spent at least half an hour to put 4 1/2 quarts in, thing is I only got 3 quarts out when I drained it, I suppose its been leaking a bit here and there. But the trans seems to be a bit smoother and quieter now though, thanks guys.
Old Dec 18, 2006 | 11:16 PM
colesdad's Avatar
I just did mine tonight also. I used the two street L's and then squeezed the funnel between the tranny and the 4x shift lever....... ended up working out fine but like Nathan, I too spent over 1/2 hour filling it.
End result, lot's quieter!
Thanks to all....
Old Dec 19, 2006 | 11:33 AM
dpuckett's Avatar
I think the factory fil 5w30 will burn up/ blow out if you dont change it regularly. My father has a 92 W350 that is IMMACULATE- no leaks anywhere. Tranny went out at about 50K (he also lugs the life out of it- 35mph and he's in 5th gear with 3.54 gears), adn I'd be willing to bet there was little to no oil. So, oil loss doesnt ALWAYS mean a leak, esp if all is clean under there.
DP
Old Dec 19, 2006 | 03:59 PM
Yeah, I guess it does take a while. I never thought much about the time aspect of it.
firstgen250
Sep 30, 2010 11:45 PM
boxcar
Apr 28, 2010 08:32 AM
jmccart
13
May 27, 2009 09:45 PM
thumbs
Nov 4, 2007 06:41 PM
doitl8r
Jun 4, 2004 11:14 AM
