Getrag Died
Originally Posted by flashgordon
Ya, went looking around there for a bit....Good sight!!!
Maybe it was a chebby
Not to bad of a price, for the NV4500
I think the low revving stock spring had a fair bit to do with many 'rags biting it earlier rather than later. Especially with a load on, the operator has no choice but to lug the heck out of the tranny, which is where the getrag really falls apart, literally and figuratively! I can shift a lot faster and smoother if the engine is wound up past 2900.
Robert
Originally Posted by Robert in W. Mi
You missed the point for most of us getting the Cummins in the first place, it was to have an engine that would pull at low RPM's... If i wanted to wind one up all the time, i would have chosen a different diesel or a gasser!
Robert
Robert
Originally Posted by mhuppertz
2,900 IS low RPM. It's destructive to lug a diesel.
You obviously haven't driven many 5-speed Macksidines(I know it probably ain't spelled right).
Shift from fourth to fifth and RPM drop from 1700 to about 300.
I think cummins are good to run all day at rated rpm, which is 22 or 2300 rpm. I don't think you will get your million miles at 2900, maybe only 500,000. I think the getrag is a functiona trans but with bad gear spread and noisy. Not surprised it is in a Dodge.
I bought the Cummins because it pulls good from low RPM's without "lugging", and without destroying itself doing so too.
Have you ever run heavy equipment with this same diesel????? You don't turn them 2,900 in a dozer or a farm tractor and they are happy all long every day pulling at low RPM's....
Robert
Robert
Robert
Engines in other applications and of other displacements making power at 300 RPM's also don't serve any prupose in this discussion. As for the 5.9 in the Dodge application, the rated horsepower comes at 2500 RPM's with peak torque at 1700. The stock gov spring does NOT FULL-FUEL all the way to 2500...if it did, I likely wouldn't have bought the 3200 spring. Shifting at 2500 (max HP) brings the next gear into play right at 1700 (max TQ) for me, which is ideal as far as I'm concerned. I've never driven a 'rag that rattles above 1600 and even Cummins recommends against putting ALL the coals to the engine below torque peak. Having said this (mostly for my own benefit, I imagine...) I will agree that the Getrag is marginal at best when compared with other reasonable options, but that from a cost-only perspective, money to swap in a different tranny would be best spent elsewhere when talking about 650 and less horsepower at the CRANK. JMOgreg
Tommy93w350
20
Nov 1, 2005 11:07 PM
Rigg4x4
Dec 13, 2002 01:40 AM
Copenhagenjunkie
Nov 29, 2002 09:10 AM
ramlovingvet
Oct 27, 2002 06:33 PM
