gauges, 16cm, pump tweakage. Done!
Old Sep 14, 2005 | 08:11 AM
lovemysan's Avatar
Installed 16cm housing monday night, iInstalled my bhaf mount at lunch, Tweaked the fuel screw 1/3 turn at break, and temped my gauges in last night. Pavement wet the best boost I could hit 17lbs. 1000 on the pyro. I'm pretty sure it needs a timing advanced a little. I see why everyone says get the pyro before pump tweaking.
Old Sep 14, 2005 | 10:03 AM
ihpower's Avatar
i take it your pyro is pre turbo. and 1000 is not bad at all. i could hit 1300 on flat ground empty easy. after i advanced it the timing helped a lot with my egt, droped them a lot. no longer can i get 1300 advancing the timing i think is a good thing it helped me a whole buch
Old Sep 14, 2005 | 11:48 AM
92DIESEL's Avatar
Did you grind the afc foot while you did the 3200 spring? If you did you could hit well over 1000* empty going WOT by 60-65mph.
Nice kick in the pants with the 16 aint it.
You dont have to get out and push in order to get out of the way anymore.
Old Sep 14, 2005 | 11:59 AM
csramsey640's Avatar
I was more impressed with the 21cm2 housing on the truck my buddy test drove last night, that sucker was kinda like....
Old Sep 14, 2005 | 05:25 PM
Don't get me started on the 21 cm.
Firstgenfanatic
Aug 17, 2008 11:25 PM
Kman9090
29
Dec 6, 2007 06:43 PM
Ramdriver15
Jan 24, 2007 09:33 AM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
