Fusible links?
Old Jan 28, 2006 | 12:25 PM
Micaiahfied's Avatar
Fusible links?
the 10 gague fusible link... at what amp does that blow?
also, at what amp would the 20 gague and the 22 gague blow?
thanks
Old Jan 28, 2006 | 12:31 PM
BC847's Avatar
1st Generation Admin
And why can't we replace those with fuses?
Old Jan 28, 2006 | 12:51 PM
if i put an electrical tester to the incoming line and on the positive battery cable it reads right at 14.7 or 14.8 volts... should i assume the the voltage regulator and the alternator are fine?
Old Jan 28, 2006 | 01:46 PM
ok i have another update... at idle i read somewhere around 15volts. if i raise the rpm the volts raise with it... i think i raised it up to like 40+volts or some... and the rpm wasn't all that high. so is it the voltage regulator?
Old Jan 28, 2006 | 03:04 PM
dsl ram's Avatar
yes you need a new regulater . Voltage should be 14 to 15 volts.
Old Jan 28, 2006 | 03:17 PM
97catintenn's Avatar
around 18volts or more and the battery goes BOOM!!
Old Jan 28, 2006 | 05:48 PM
ok the new regulator didn't fix it... and i even ran a 14 gauge wire from the regulator directly to the ground the the alternator uses... please help at 3/4 throttle it's still reading 40+volts (don't worry it's not making it to the battery)
Old Jan 28, 2006 | 06:12 PM
next thing on the list to replace would be the alternator.
Old Jan 28, 2006 | 08:02 PM
Check the wiring. It sounds like the alternator is full fielded. There is nothing wrong with the alternator if it can crank out 40 volts.
BearKiller
Dec 11, 2007 04:57 PM
Mopar Kid
Sep 30, 2007 05:33 PM
broncobilly
Mar 21, 2007 11:33 PM
woodrat
Dec 10, 2006 05:43 PM
BC847
Jun 8, 2006 10:31 PM
