Fuel Pump Leak!!
Old 07-13-2006 | 04:50 PM
whereswaldo250's Avatar
Angry Fuel Pump Leak!!
Hey guys ,
My fuel pump on my 92 diesel is leaking and I was wondering if there is a way to fix it without buying a new one. I have already checked with dodge and it is 200.00 for a new one. Any ideas?
Thanks
Old 07-13-2006 | 05:38 PM
440forPOWER's Avatar
If your talking about the lift pump I just replaced mine and picked one up from NAPA for $75.00. Good Luck
Old 07-13-2006 | 05:49 PM
He's either talking about the lift pump or he left out a zero. usdieselparts.com has them for around $40 shipped.
Old 07-13-2006 | 07:29 PM
HAHA sorry lift pump that is what I meant. Is it hard to replace?
Thanks I'm kinda new at the whole diesel scene.
Old 07-13-2006 | 07:33 PM
Not difficult at all. If you've changed a fuel pump on a carbureted gas engine there will be no surprises for you.
Old 07-13-2006 | 08:44 PM
gman07's Avatar
Only one thing to add: if you're looking for quite a bit more power in the future you may want to look into a piston lift pump. They are quite a bit more expensive, but they won't starve the VE in the upper HP levels. However, if you plan on staying stock or close to it, the piston pump isn't worth it.
Old 07-13-2006 | 09:24 PM
jrussell's Avatar
If the stock pump is still within spec, at what HP level should one generally go to a piston lift pump?
Old 07-14-2006 | 04:44 AM
bgilbert's Avatar
161hp at the flywheel.
Old 07-14-2006 | 05:41 AM
IMO, if you change injectors it's time for the piston pump.
Old 07-14-2006 | 10:57 AM
Ace's Avatar
Ace
What about electric replacements (a.k.a Walbro, etc.)? Anybody doing that on the 1st gens?
Old 07-14-2006 | 03:34 PM
Stomp has an Aeromotive I think.
Old 07-14-2006 | 04:22 PM
apwatson50's Avatar
I just installed my piston LP this last weekend and all I can say is WOW!! I practically tripled my FP at idle, went fro 6psi to about 15psi. Don't know what it is at WOT but i'm sure its more than 0psi. Before it would pull to about 3000rpms and pretty much that was it, now it'll pull to 3250 and probably keep pulling but I get scared and back out.
Just wish I would have put it on sooner as my IP is dying.
Old 07-14-2006 | 06:46 PM
Hey thanks guys,
How much more would a piston pump be?
Old 07-14-2006 | 08:03 PM
frostie's Avatar
I bought mine through Cummins I spent about $170 for everything to convert to piston pump.
Look in the tech section, I believe all the part numbers are there.
Jaybug
12-24-2013 11:23 PM
ZPOD
18
09-23-2010 10:37 AM
donhov
26
01-06-2006 07:29 PM
Bobcat698
11-21-2005 09:19 PM
amartinson
0
05-04-2003 01:55 PM
Quick Reply: Fuel Pump Leak!!
