Fuel pressure gauge
Old Sep 19, 2008 | 06:38 PM
leeboy's Avatar
Fuel pressure gauge
Hi, is a fuel pressue gauge just as necessary for VP and lift pump on the 1st generation as it is on the 98-02 generation?
Old Sep 19, 2008 | 07:15 PM
SkinnyBTN's Avatar
Yes! I burned up a brand new pump cause I misunderstood how much fuel pressure was needed. I was running a 7psi napa electric pump till just before her demise !!! I read somewhere you need a min. of 5psi at idle. So I had approx. 7psi at idle. What could be wrong with that? Oh, and had the pump turned up w/ POD's. I bet that pump cavitated as much as it pump fuel. I wondered for the longest time why I felt it drop off on the top end I get sooo tickled and aggrivated w/ myself over that one Oh well, ya live ya learn!
Old Sep 20, 2008 | 06:30 AM
On a stock truck, a fuel pressure gauge is not really necessary. The VE will pull its own fuel through a dead lift pump with no harm done as long as there's only 200 hp of fuel involved. I think any truck with big injectors needs a fuel pressure gauge, though.
Old Sep 20, 2008 | 06:58 AM
SkinnyBTN's Avatar
I'm sure your correct. I'm just overly paranoid since I'm on my 3rd. pump in 1.5 yrs. The first one, one that came on the truck died before I turned it up. Lift pump went bad and I didn't know it. I reckon there were some other factors involved like the switch to ULSD. I installed an oil pressure guage for less than $20 for a fuel pressure guage and have been satisfied. It at least letting me know my Holley blue is on its way out. With the sinsetivity of the VE I think a Fuel Pressure guage should have been installed from the factory .
Old Sep 22, 2008 | 06:21 PM
leeboy's Avatar
Ya, this truck is bone stock.....I just thought a gauge could help find a problem before the problem got REALLY expensive. What is the bennefits of having that gauge?
Old Sep 22, 2008 | 06:44 PM
SkinnyBTN's Avatar
It will tell ya if your lift pump is bad before you burn up the IP. But as Wanna said, "On a stock truck a fuel pressure gauge is not really necessary" If ya want one and don't want to spend much, an oil pressure gauge works quite well. <$20 at Auto Zone
Old Sep 22, 2008 | 07:42 PM
BearKiller's Avatar
A fuel-pressure gauge between the fuel-filter and injection-pump is a very handy diagnostic tool; I watch my fuel-pressure closer than any other of the many gauges I have.
Once you learn what pressure is "normal" for your set-up, you can usually catch most fuel-feed issues before they shut things down.
Even better is to have two gauges, one ahead and one after the filter; with two, if the post-filter gauge starts losing pressure and the pre-filter gauge shows fine, then you know for certain that the problem lies within the filter.
Many is the fuel-filter that has been replaced when it was not at fault, simply because it is the first suspect in the chain of crime.
Old Sep 22, 2008 | 10:10 PM
randyswelding's Avatar
ok so how do you and where do you tap in to the line genos has a bango bolt but i dont know if itll fit, cause im lookin at one too
Old Sep 23, 2008 | 07:46 AM
SkinnyBTN's Avatar
I am running 3/8" rubber fuel lines so I just purchased a T with the proper threads on the Up part of the T. I hope that makes sense.
Old Sep 23, 2008 | 08:12 AM
BearKiller's Avatar
This is the one that FITS the 1st Gen. engine, regargless of what it says :
http://www.genosgarage.com/prodinfo....BF-LONG-TAPPED
It is the one you will use if you are not replacing the rigid metal lines with a "Big Line Kit".
Some of my trucks use the tapped banjo-bolt, others have 3/8 rubber lines and use some manner of TEE-fitting for the fuel-pressure sender.
Either way, install a pressure "snubber" from McMaster-CARR to smooth out the surges, so that the gauge-needle stays steady and doesn't constantly flinch.
dodgeguy71
17
Jan 19, 2012 12:52 AM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
