Less power???
Old Sep 21, 2008 | 02:36 PM
89f150's Avatar
Less power???
Ok well put the 3200 spring in and i took the afc lever out and cranked the starwheel. It seems like less power and when its floored it seems like it cuts out. Any ideas? maybe i should undo the starwheel?
Old Sep 21, 2008 | 02:44 PM
Alwaysworking's Avatar
alwaysonDTR
if you took th afc leaver out the starwheel doesn't do anything anymore, my guess is the throttle shaft is indexed wrong.
how much smoke when you hammer it?
Old Sep 21, 2008 | 02:56 PM
C/PRD/'s Avatar
Indexing sounds off. The only adjustment you have is the fuel screw now.
Old Sep 21, 2008 | 03:00 PM
89f150's Avatar
About the same as before and only when i step on it
Old Sep 21, 2008 | 03:51 PM
89f150's Avatar
and it also had less boost
Old Sep 21, 2008 | 05:32 PM
RSWORDS's Avatar
Possibly Putting Out the fire? Try to not stomp on it and just roll into the throttle.
Old Sep 21, 2008 | 05:36 PM
archer39's Avatar
you might have backed out the full power screw when you where in there. do you remember how far it was in before you did the spring?
Old Sep 21, 2008 | 05:41 PM
89f150's Avatar
i tryed rolling into the and the same and and the full power screw is cranked
Old Sep 21, 2008 | 09:45 PM
89f150's Avatar
what way should i move the shaft on it
Old Sep 22, 2008 | 01:38 AM
alwaysonDTR
did it idle normal when you started it after pulling the afc lever?
Old Sep 22, 2008 | 11:46 AM
89f150's Avatar
ya it idles fine
Old Sep 22, 2008 | 06:43 PM
89f150's Avatar
Ok well i fixed the shaft for the throttle now the idle is super high so i had to put the idle almost all the way out and back the power screw just to get it to lower what should i do to lower the idle anbd screw the power screw back in?
Old Sep 22, 2008 | 09:45 PM
alwaysonDTR
did this fix the power issue?
Old Sep 23, 2008 | 12:34 AM
89f150's Avatar
Ya its alot fasater and it seems to shift faster also
Old Sep 23, 2008 | 01:00 AM
alwaysonDTR
okay then if you have no idle adjustment on the idle screw you index the throttle shaft and swap the throttle linkage and return spring places
