fuel lines
Old Jan 19, 2008 | 09:29 AM
rydDiesel174's Avatar
fuel lines
thanks free89 for the tip on bleeding the fuel. here is my other question, i really dont want to bend new 5/16 fuel lines. i am ok at bending the brake lines i did but anyway can i use -6an fuel hose. it says that it wont collapse under heat, so will it be ok to use for a supply and a return?????
Old Jan 19, 2008 | 04:29 PM
Free89W350's Avatar
Yes that should be fine.
Check out these links. BC847 did the original and I did the second one for the non ic trucks.
BC's:
https://www.dieseltruckresource.com/...d.php?t=151190
Mine:
https://www.dieseltruckresource.com/...d.php?t=174241
Make sure you read the top one first, I believe he used the 6an. I just used regular fuel hose when I did mine because I had all needed fittings at work and I was to cheap to buy the other hose.
Good luck and make sure you keep everything clean and take your time.
Old Jan 20, 2008 | 06:15 AM
Make sure the fuel line is rated for diesel. Gasser line will turn to mush in a couple months.
Old Jan 20, 2008 | 08:43 PM
rockfoot's Avatar
Wanna,not trying to steal the thread, but what type of flex hose type fuel line material works for diesel fuel. Neoprene hose is no good? I just changed mine and I got just regular "fuel line" from advance.....
Old Jan 20, 2008 | 11:47 PM
Free89W350's Avatar
When I did mine I got the hose from Napa and I asked if it would work with diesel fuel. Some hoses say what they are rated for such a gas or gas and diesel fuel.
Old Jan 21, 2008 | 04:47 AM
Look for "SAE" and the codes "30R7", "30R2", "30R3" or "100R4" printed on the hose. I listed them in order of strength, but all are OK for our low pressure fuel systems.
Old Jan 21, 2008 | 07:52 PM
rockfoot's Avatar
Thank you.... Thank you very much
Old Jan 22, 2008 | 12:32 PM
rockfoot's Avatar
Just checked mine out, the ones that I just put on there.... SAE "30R6''... You didn't list it but is R6 Okay? I was looking for one of the specific numbers that you listed....
Old Jan 22, 2008 | 04:55 PM
kiszka6911's Avatar
According to goodyear their version is rated for diesel.
http://www.goodyearep.com/ProductsDetail.aspx?id=6082
Old Jan 22, 2008 | 07:00 PM
BearKiller's Avatar
Wink Here Is What I Have Been Using
From NAPA = GATES HOSE fuel line hose
3/8" 25' roll part # H177
SAE 30R7
XL Fuel Line
Wannadiesel, you listed them in order of strength.
In which order ??
Is 30R7 best or least ??
Thanks.
I also have a partial roll from Advance that I bought in a Saturday-everywhere-else-closed pinch, made in USA, no visible name-brand, SAE 30R6.
This hose easily squishes through the little slots in the hose-clamps and is obviously not of the quality of the Gates hose.
Old Jan 22, 2008 | 07:25 PM
30R7 is the wimpiest, but it will still be OK with a stock diaphragm pump or 1st gen piston lift pump. The 100R4 is only needed on high pressure (over 30 psi) systems.
billmac
0
Mar 20, 2006 03:03 PM
chucktownsend5
Mar 8, 2005 08:21 PM
MrKen
Feb 25, 2005 04:22 AM
debolton
24
Jun 29, 2004 09:22 PM
hellotbone
Sep 1, 2003 08:46 PM
