Fuel Gauge ??
Old Oct 13, 2007 | 02:11 PM
BearKiller's Avatar
Question Fuel Gauge ??
Early 91 D-350, the gauge don't work, but the LOW FUEL light does.
What is the most likely culprit, the sending unit or in the dash ??
Thanks.
Old Oct 13, 2007 | 07:17 PM
Sending unit. To be sure, ground the dark blue/yellow wire at the sender. You should show a very full fuel tank.
Old Oct 13, 2007 | 10:32 PM
BearKiller's Avatar
Do I do this with the wires plugged to the sender, or un-plugged ??
Thanks.
Old Oct 14, 2007 | 10:40 AM
Either way, doesn't matter.
Old Oct 14, 2007 | 10:59 PM
BearKiller's Avatar
I grounded the blue/yellow wire and the needle went way past FULL.
I had the whole assembly out, for other reasons, and I can see no reason why the gauge shouldn't work, but I am no electronics expert.
Somehow, in the process, I lost my LOW FUEL light.
It came on intermittently a few times, with the unit not in the tank, but the wires plugged in; but, after sliding the unit back in the tank, no light.
Can I repair this sender or is that impossible ??
Thanks.
Old Oct 15, 2007 | 12:00 PM
rockfoot's Avatar
Question
I tried to repair mine with no luck.... not sure how it is presenting resistance unless it is the material that the thing is made of... or built into it somehow... I actually busted mine to see if there were any internal resistive wires or something in there and I couldn't see anything... I am still curious to know how it works....
Old Oct 16, 2007 | 04:33 PM
Am I good or what?
Thanks.
I would just get a new sender.
Old Oct 16, 2007 | 06:13 PM
BearKiller's Avatar
Do I just get the little electric board gizmo; or, do I have to buy that whole big business ??
Where do I find and about how many dollars should I expect to pay ??
Thanks.
Old Oct 16, 2007 | 06:18 PM
You get the little gizmo with the float.
Original p/n is 52004932, allegedly superseded by 52017992.
Should be around $50.
Old Oct 16, 2007 | 06:25 PM
BearKiller's Avatar
I think I will make me a dipstick.
Or do like I do on some of my other rigs and use a notched tobacco stick.
Thanks for the part number.
Old Oct 17, 2007 | 06:41 PM
Wow, you are frugal.
Old Oct 17, 2007 | 10:45 PM
BearKiller's Avatar
If that is just another fancy word for being financially challenged, then you can say that again.
nrussell
Jul 23, 2008 08:58 PM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
