Fuel in engine oil
Fuel in engine oil
I have been getting excessive fuel in my engine oil. I replaced the lift pump & changed the oil but still have the problem. 2 qts. over full at 600 miles since oil change. Any ideas? 92 W350 with ve pump & intercooler
Front seal on the IP. You have to pull the pump to repair it. If the engine is running right otherwise, that's about all it could be. If you have a serious miss, it could be major internal, like piston, head gasket, etc.
Exactly what I thought as soon as I saw your thread. Not the quickest, or easiest of projects...but you need to stop that fuel from getting into your oil. You also need a VE pump re-seal kit....DGK-121 from your local diesel shop, or other on-line sources.
Piece of Cake! I did my first one in about 6 hours. Once the pump was out, I carefully drilled a small hole in the seal and threaded a screw into it. I then pulled on the screw to wiggle the seal out of the bore. I wrapped the keyway with a bit of electrical tap as to protect the seal then reinstalled the seal over the shaft with a socket of the appropriate size as a driver and a coating of locktite around the outer surface.
ClassA4x4
May 16, 2013 11:49 AM
IPDiesel
Dec 29, 2010 09:21 AM
rufushusky
May 10, 2009 12:41 PM
realoldandcrust
Feb 14, 2008 09:53 AM
rico334
Jan 3, 2005 08:10 AM
