Copper tack spray insetad of the gaskets
Old Feb 16, 2013 | 06:10 PM
mhuppertz's Avatar
Anyone ever tried installing POD's with just copper tack instead of the copper washers? Was thinking about lapping the injector bodies like you would a valve to make sure I have a good seal.
What the heck, I'm going to try it. My truck ran frighteningly well before, so it should be interesting. Maybe the POD have will be less!
Old Feb 16, 2013 | 07:26 PM
93flatbed's Avatar
Isn't that going to lower the injector tip twords the piston a scary amount? Also you feel it will stop the compression?
Old Feb 16, 2013 | 07:29 PM
mhuppertz's Avatar
Not sure I understand, the injector is over the bowl in the piston. Don't understand the compression comment, can you rephrase?
Old Feb 17, 2013 | 06:29 AM
j-fox's Avatar
The copper washer is a compression seal along with being a spacer to place the tip where it needs to be in the bowl.
Old Feb 17, 2013 | 08:05 AM
j_martin's Avatar
A little goop won't replace the sealing of the copper washer. You're dealing with dissimilar metals, heat, and impact.
Old Feb 17, 2013 | 10:02 AM
mhuppertz's Avatar
Appreciate the input. It's just that valves are dissimilar than their seats, but they seal well. Shouldn't be any movement there, if there were compression would leak out. Copper tack is made of copper so it transfers heat. Been using it on steel shim head gaskets for 36 years without one failure. Since the spray pattern is so much wider on POD's the further down I can get them the more efficient the combustion/flame front. As it is no I have competing flame fronts that waste energy (and lots of blow-by and haze).
Old Feb 17, 2013 | 11:18 AM
93flatbed's Avatar
I see your points, and hope you prove me wrong but I don't see it working. Will the hold down nut even tighten the injector down enough to seal? What size washers were you running before, I think they come in 0.010 and 0.020", wonder if a guy in your situation could find a very thin washer to seal it and get the fuel in the bowl?
Old Feb 17, 2013 | 11:50 AM
mhuppertz's Avatar
Good points. I think I have plenty of leeway on the hold down nut. Lapping the seats with dye should tell me weather I can make it work. If not I will try to find wafer thin seals. I need to get those tips down as far as I can.
Old Feb 17, 2013 | 02:08 PM
j_martin's Avatar
The valve to seat joint is a totally different deal. The metals are hard steel and hard steel. Besides that, there is much movement between the surfaces.
The injector is steel, and the head is cast iron, with very different thermal expansion characteristics.
Anyway, you're going to try it. Let us know how it works.
Old Feb 17, 2013 | 02:50 PM
mhuppertz's Avatar
You are probably right. I think that in such a small scale the expansion differences would be negligible. I am confident enough with my calculations that I am willing to give it a try. The worst that can happen is I have small combustion spike leaks. I will check with soapy water!
Old Feb 17, 2013 | 03:27 PM
bobva's Avatar
read this
https://www.dieseltruckresource.com/...e-t309819.html
Old Feb 17, 2013 | 05:13 PM
mhuppertz's Avatar
Originally Posted by bobva
Read it. Don't think it applies to POD's, which are marine injectors designed for marine pistons that have larger bowls. Conventional wisdom (as I understand it) has always been that POD's require the thinnest washers possible to get the spray angle down farther for a better burn.
Of course all of this could be crap. I will post the results, good and bad.
As for now, gotta figure out how many new valves I have to buy!
B18B1LS1
Feb 8, 2008 03:00 PM
sliqwille04
Jan 5, 2008 11:42 AM
CReed
23
Sep 29, 2007 02:38 PM
wildchild97
Sep 25, 2007 12:37 AM
90dodge
Jan 4, 2006 03:57 PM
