Why diesel engine oil gets darker than gas engine's
Old May 11, 2013 | 08:18 PM
ClassA4x4's Avatar
A basic question I haven't learned the answer after almost 3 years with my Cummins.
Old May 11, 2013 | 08:45 PM
MARF75's Avatar
Soot from the fuel maybe ???
Old May 11, 2013 | 09:00 PM
Onemoparnut's Avatar
Definitely soot
Old May 12, 2013 | 10:18 AM
peckens's Avatar
my 93 gets black right away, my 03's oil would still look new after 5k miles
Old May 12, 2013 | 10:37 AM
cougar's Avatar
On both mine, I can change it, start it , shut it down and it's black.
Old May 12, 2013 | 10:40 AM
MARF75's Avatar
I have 4000 on my oil right now and I can read the words on the dipstick thru it. 116,000 miles
Old May 12, 2013 | 10:42 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
The same with mine...Maybe it is something to do with the mods we do...More heavier fueling compared to stock..Just a guess...
Old May 12, 2013 | 11:05 AM
ClassA4x4's Avatar
How's that happening? Please tell us your secret.
Old May 12, 2013 | 11:07 AM
J. Millspaugh's Avatar
I have a 93 with 170,000 on it. The oil has always been clear even when I change it every 5000 miles you can still see the writing on the dipstick.
Old May 12, 2013 | 12:47 PM
When I chipped my 24V, I noticed the oil got dark much quicker, as did the last bit of my bed near the exhaust tip.
Old May 12, 2013 | 01:39 PM
ClassA4x4's Avatar
Stock tuned?
What's your secret?
Old May 12, 2013 | 02:17 PM
deanhinsley1963's Avatar
Definately the more fuel and also if you just run short trips and not loaded will darken oil faster. And soot is a major factor also.
Old May 12, 2013 | 07:12 PM
jerseybud's Avatar
Never have figured this out.....I assume soot
Our 1968 350 John Deere 3 cylinder blackens the oil immediately
Our 1985 JD2550 4cylinder non-turbo blackens the oil immediately
Our 1998 JD6410 4 cylinder turbo blackens the oil a little less slowly despite a bad IP
Our 1993 W250 with 290k blackens the oil in about 3-4000 miles but nowhere near what the tractors do.
I've also heard that its bad if the oil isn't black on a diesel? I don't know what to think. Using rotella t 15w-40 in all of them
Old May 12, 2013 | 11:42 PM
j_martin's Avatar
It's soot from the fuel. How much depends on how clean the burn is and also engine clearances, especially pistons and rings. Diesel rated oils suspend it harmlessly in reasonable amounts, which is pretty black.
Old May 13, 2013 | 03:46 AM
Jim Lane's Avatar
Another vote for SOOT, like he said. ^^^^^
It also makes a mess when you spill it trying to get it back into the bottle.
Jim
