fass issues
fass issues
i put a fass on my 91.5 cummins. its running out of a fuel cell in the bed. the fass is mounted in the bed aswell. I have all the lines hooked up correct and with hose clamps. The truck will start and run for like 15-20 seconds and then die. no throttle responce after 10 or so seconds.
Sounds like you got air in the system. crack a few injector lines and crank it till fuel squirts out real good.
happened to me when i did the fuel filter changeout the other day..
does it just crank and crank when you try to start it ???
i plugged the stock return line and its at about 17 psi. i got all the air out of the lines and it ran fine. Than all of a sudden i lost fuel pressure and it died. Im runnin a 32 gallon fuel tank out of a boat. Its all aluminuim with a 3/8 draw straw to the bottom of the tank. I can seem to figure out what the deal is?
when the pump return line wasnt plugged the truck wouldnt run for more than 15 seconds. So i plugged it because the fass has a spring and ball that releases pressure once it gets 17psi. i think i have it figured out, but i have run into another problem. I can only build 10psi of boost and it takes forever to get there. there is no smoke at all and my pump is maxed no afc and a denny t pin.
got the fass figured out. boat fuel tanks suck. it works perfect out of a 5 gallon gas can. But now i have no power. It builds 10psi @ 850* through the floor. What do i do with the injector return line? i put my hand over the turbo and watched all the intercooler boots suck flat. so i dont think there is a boost leak. The truck ran wonderful with the auto, i put a nv4500 in it and never touched the pump over the 8 months it sat. Why wont my pile make power?
