Electrical Issues, Possible ECM ?
Old Apr 15, 2008 | 08:16 AM
ekk33's Avatar
Starting to have problems with what i think is the computer,
Sometimes in the morning, i dont have a speedometer, or tach, and the voltmeter reads low, and obviosly without a speedometer, i have no overdrive,
Drive a couple miles and it starts to work again,
Any ideas,
Next time it happens i am going to verify, if it is actually charging or not,
Eric
Old Apr 15, 2008 | 09:56 AM
JD730's Avatar
How cold are these mornings? Is the wait to start light flashing sometimes?
I think your right on the mark with the ECM. I've had 2 that did similar things to me.
Old Apr 15, 2008 | 10:02 AM
JD730's Avatar
I almost forgot, it could also be the crank sensor, the dodge PCM uses that to tell if the engine is running.
Old Apr 15, 2008 | 10:52 AM
ekk33's Avatar
Is there anything else that the crank sensor sends a signal to?
Going to pull the plug apart and check the connections there tonight, and dielectric grease it
Mornings werent to cold, 20-25 F just started doing it, didnt do it when it was really cold,
On to solutions,
Bypass the ECM ???
The overdrive is easy, just go to manual switch,
What about the speedometer and the tach, any easy way around those?
Old Apr 15, 2008 | 05:53 PM
I'm betting PCM too. Check the connector for crud first, though.
You can get the speedo working with a VSS for a manual trans truck.
Jnoble
Mar 27, 2012 07:01 PM
jwayne575
Jul 29, 2010 09:18 PM
Philabuster
Mar 3, 2009 04:51 PM
77ctd
Jan 7, 2009 10:56 AM
dutchboy
Sep 5, 2006 04:58 PM
