Electric fuel pump questions.
Old Aug 11, 2008 | 08:06 AM
super-duty's Avatar
I am doing a 93 ic conversion in an off road truck and I am going to run a blue pump and my questions are.
1. What pressure do I need to reg. it at?
2. Do I need the manual on the side of the block still?
Thanks in advance.
Old Aug 11, 2008 | 04:17 PM
Why not just use the mechanical pump that's there?
A Holley Blue will work OK, you can crank it all the way up. With as unreliable as the Holley pumps are, I'd keep the mechanical pump.
Old Aug 11, 2008 | 06:15 PM
super-duty's Avatar
Wanna I will be useing a fuel cell. I just put holley pump up yhere for reference I have a few differnt ones that I could use. So I am assuming you cant over psi it?
Thanks.
Old Aug 11, 2008 | 06:48 PM
Montana2x2's Avatar
On a VE 15 PSI is about all you want or you run the risk of blowing a seal out of the IP
Old Aug 11, 2008 | 08:32 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
The blue pumps get a bad rap for some reason, mine has been on for a year and its still kickin,I know there are better pumps out there, the Blue is fairly reliable IMO, Its never left me on the side of the road
My blue runs about 14 psi unregulated
Old Aug 11, 2008 | 10:52 PM
JQmile's Avatar
Do you have a pressure gauge? Can you pull your blue pump below 14psi?
Old Aug 11, 2008 | 10:56 PM
I can suck it down to 2 psi, I know I need more fuel
Old Aug 12, 2008 | 03:49 PM
Oh, you can, just not with a Holley Blue. 15-18 psi is about all you want.
Not understanding why you need an electric pump to go with your fuel cell?
Old Aug 12, 2008 | 06:31 PM
super-duty's Avatar
Just wanting to make sure I get fuel to the engine. Is there something that I am not understanding?
Old Aug 12, 2008 | 08:24 PM
BearKiller's Avatar
The best of both worlds is to install a piston-lift-pump, in place of the wimpy stock diaphragm-pump, then install the electric-pump of your choice in a by-pass line, such that by merely flipping a switch, the electric comes into play.
The piston-pump will supply all the fuel any sensible situation ever requires, while the electric is on standby as an emergency back-up and for priming filters, etc.
Old Aug 12, 2008 | 08:33 PM
Fergavs's Avatar
If you want a serious electric pump dont bother with a holley. If you do a search you will find many people that didnt have great luck. Use a Raptor 100 pump. They come with a lifetime warranty which basically makes them amazing. They also offer advance replacement so they will send you the replacement before you ship yours back. This way you only gotta get under the truck once if you ever do have a problem. Very well priced to, check the site: http://www.pureflowtechnologies.com/
You will not need a pressure regulator either as its built in. Just set it where you want and go.
Old Aug 13, 2008 | 07:32 AM
super-duty's Avatar
Thanks guy's im still learning and everything helps.
Old Aug 13, 2008 | 06:52 PM
If the engine is going to stay close to stock there is no reason to complicate the fuel system. Just run a fuel line to the mechanical pump and let it pull from the tank.
Old Aug 13, 2008 | 10:23 PM
Exekiel69's Avatar
The only reason why I currently use electric pump is bc the mech pump can leak fuel inside the engine which is something not uncommon on IH 7.3l engines so My plan is to remove the stock pump on My 89 5.9l and replace it with an electric facet pump (max 10psi), the one used by carrier.
Diesel Girl
18
Oct 6, 2013 03:03 PM
cj5er
Dec 20, 2009 09:19 PM
stock600
Apr 8, 2008 11:30 PM
xeus
Sep 5, 2006 08:33 AM
Mark Thomas
Jul 30, 2004 06:52 PM
